franco72 6 Posted April 16 Posted April 16 Hi team, I’m experiencing a sync issue when using Vimu Media Player as an external player in the Emby app for Android TV (Ugoos AM6b+ device). The issue: When I start "Movie A" and stop it halfway, the position is saved correctly in Emby. When I then start "Movie B", Vimu prompts me to resume from the timestamp of "Movie A". If I disable "Resume from last position" in Vimu settings, every movie starts from 00:00, even if Emby has a saved resume point. It seems Emby is not passing the resume_at or start_index parameters in a way that Vimu can interpret, or it's reusing the Intent data from the previous session. I’ve contacted the Vimu developer, and he suggested that Emby might not be using the correct API constants for Vimu. He provided the API documentation here: https://vimu.tv/player-api/ Could you please check if the Emby Android app correctly passes the position or start_time extra when calling Vimu as an external player? Thanks! 1
ebr 17043 Posted April 16 Posted April 16 Hi. We do not have this integration with anything other than MPV. Why do you feel you need to use an external player?
franco72 6 Posted April 16 Author Posted April 16 48 minutes ago, ebr said: Why do you feel you need to use an external player? Thank you for the reply. I understand you currently only have this integration with MPV, but for high-end home theater users, an external player like Vimu is a necessity for two critical reasons that the internal player currently cannot handle: 1. Dolby Vision Profile 7 (FEL) Support: Vimu is one of the few players that correctly handles Profile 7 to Profile 8 conversion on the fly. Without this, my projector defaults to HDR10 when using the internal Emby player, losing the benefits of Dolby Vision. 2. Buffering and Cloud Streaming (Real-Debrid): I frequently stream high-bitrate remuxes via Real-Debrid. Although I have a 200 Mbps connection, occasional ISP speed fluctuations are inevitable. In Vimu, I can set a 1 GB buffer, which completely eliminates stuttering by creating a massive "safety net." The internal Emby player, with its much smaller buffer, constantly hits frame freezes during minor speed drops, and sometimes it freezes indefinitely. For files with a 100 Mbps bitrate, a massive buffer is the only way to ensure a seamless experience when streaming over the network.
ebr 17043 Posted April 16 Posted April 16 What device are you running on that has the RAM for a 1GB video buffer?
franco72 6 Posted April 16 Author Posted April 16 (edited) 2 hours ago, ebr said: What device are you running on that has the RAM for a 1GB video buffer? I have two Android devices that handle a 1GB buffer perfectly. The first is the Ugoos AM6b+ connected to my TV. The second is the Vidda C3 Ultra projector (MediaTek MT9681 processor, 8GB RAM + 128GB storage, 4K Dolby Vision), where both Emby (Lifetime licenses) and Vimu (Lifetime licenses) are installed directly on the projector's OS. With 4GB of RAM on the Ugoos and 8GB on the Vidda, there is more than enough memory to allocate a large buffer for high-bitrate streaming. This is why I rely on Vimu — it allows me to actually utilize this hardware to ensure smooth playback of 100Mbps+ remuxes, something the internal player cannot do. Edited April 16 by franco72
franco72 6 Posted April 18 Author Posted April 18 On 4/16/2026 at 5:28 PM, ebr said: Why do you feel you need to use an external player? Some friends pointed out that the latest Jellyfin Android TV client now fully supports Vimu as an external player for the exact same reasons I mentioned earlier. I tested it yesterday, and it’s true: Jellyfin now passes the resume tokens to Vimu perfectly. However, I much prefer the Emby interface; it looks far more polished and professional than Jellyfin’s layout. In my opinion, as a paid Emby user, it would be great to see the same level of external player integration that the free Jellyfin app already provides. It would make Emby the undisputed leader for high-end home theater enthusiasts who rely on Vimu for the best possible playback experience.
Luke 43568 Posted April 24 Posted April 24 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
gluk147 8 Posted June 14 Posted June 14 Same problem. Tried the latest versions of Android and Android TV. Saving viewing position does not work with Vimu 1
signde 33 Posted June 14 Posted June 14 Not to derail this thread but I hope you know that as an Ugoos AM6b+ owner you can run the avdvplus fork of CoreELEC that would allow you to do LLDV including full FEL rendering to your non DV capable projector. This would be much better than using on the fly P7 to P8.1 conversion as that process drops the DV P7 enhancement layers. You can connect CoreELEC to your Emby library one of a few different ways, see the Kodi addons.
franco72 6 Posted June 15 Author Posted June 15 8 hours ago, signde said: Not to derail this thread but I hope you know that as an Ugoos AM6b+ owner you can run the avdvplus fork of CoreELEC that would allow you to do LLDV including full FEL rendering to your non DV capable projector. This would be much better than using on the fly P7 to P8.1 conversion as that process drops the DV P7 enhancement layers. You can connect CoreELEC to your Emby library one of a few different ways, see the Kodi addons. Yeah, I know that, of course. I have a standalone Ugoos AM6B+ box flashed with CoreELEC. What's more, I’m using the modern Arctic Fuse 3 skin, so it looks really sleek. But I still like the Emby interface better; it's just more user-friendly. And if the free Jellyfin managed to integrate Vimu, why hasn't Emby done it yet? Right now, a friend of mine is rebuilding the Emby client using AI, and he’s already got this integration partially working. If some random guy can pull this off, why can’t the Emby developers??? Especially since the app already has an "use external player" option in the settings—it just needs to be properly polished.
Luke 43568 Posted June 15 Posted June 15 On 6/14/2026 at 9:50 AM, gluk147 said: Same problem. Tried the latest versions of Android and Android TV. Saving viewing position does not work with Vimu What version number did you try?
gluk147 8 Posted June 16 Posted June 16 On 6/15/2026 at 9:28 PM, Luke said: What version number did you try? emby server 4.10.0.14 beta emby android 3.5.34 ember android tv 2.1.46g vimu latest from google play store
Luke 43568 Posted June 16 Posted June 16 Quote why can’t the Emby developers OK, it's something we can look at, but up until now there hasn't been much talk about Vimu. It's usually the bigger ones like mx player or vlc. 1
franco72 6 Posted June 17 Author Posted June 17 10 hours ago, Luke said: OK, it's something we can look at, but up until now there hasn't been much talk about Vimu. It's usually the bigger ones like mx player or vlc. Yeah, that's true. However, Vimu has been gaining a lot of traction lately because of its unique features. First, it offers flexible manual control over the pre-buffer size (the developer specifically optimizes the player for smooth online torrent playback via TorrServer). On top of that, it has a feature that was previously exclusive to Kodi: playing Dolby Vision Profile 7 as actual Dolby Vision by converting it on the fly to Profile 8 for MKV and M2TS files. Along the way, Vimu implemented advanced audio passthrough support and flexible conversion to AC3 or EAC3 for audio formats not natively supported by the TV box, all while preserving the multichannel layout. Honestly, I don't know of any other player that offers this kind of functionality while remaining so straightforward to configure. 1
Luke 43568 Posted August 3 Posted August 3 On 7/20/2026 at 5:25 PM, gluk147 said: Is there any news about adding this feature? Hi, I don't have an ETA, but it's something we can look at. Thanks. 1
vanor 4 Posted September 2 Posted September 2 I'd like to add (in addition to the above features) why this particular player is important. While MX and VLC handle video decoding well, it handles audio more accurately with localized audio tracks. With older movies, a significant number of built-in TV players stutter. There's also the issue of voices being relegated to the center channel and appearing too quiet. These aren't features most people need in a built-in player, so I'd like tighter integration with an external player. and I apologize for the poor search before creating a topic 1
franco72 6 Posted September 23 Author Posted September 23 On 8/4/2026 at 12:21 AM, Luke said: Hi, I don't have an ETA, but it's something we can look at. Thanks. Hello. I built the integration between Emby and Vimu myself. To be precise, I am someone with zero programming background who simply explained the task to ChatGPT, and after a series of failures, it made a working integration. For ethical reasons, I cannot share this version publicly, but ChatGPT can provide you with all the necessary information: Technical description of the Emby Android TV → Vimu integration The integration uses Vimu (net.gtvbox.videoplayer) as an external playback engine while keeping Emby Android TV responsible for library navigation, playback state and server-side resume positions. The important discovery was that there are two independent resume mechanisms involved: Emby's server-side playback position. Vimu's own local resume database, particularly when Vimu's "Resume by filename" option is enabled. Emby may provide playback URLs whose final path component is generic, for example stream.mkv or master.m3u8. Vimu's filename-based resume mechanism uses the final path segment of the URI as its resume identity. Consequently, unrelated Emby items can collide in Vimu's local resume database. Simply replacing the final component of an Emby URL is not safe. In particular, HLS endpoints such as master.m3u8 are functional server routes rather than arbitrary filenames. Renaming them can make playback fail. The working solution is therefore to make Emby the single source of truth for resume position and prevent Vimu's filename-based resume database from reusing an old position. Before launching Vimu, the client creates a small HTTP server bound exclusively to 127.0.0.1 on an ephemeral port. For every individual playback launch, a new alias filename is generated using the Emby Item ID plus a random UUID, while retaining an appropriate file extension. Conceptually: embyvimu_<EmbyItemId>_<random-UUID>.<extension> Vimu is launched with a URI similar to: http://127.0.0.1:<port>/embyvimu_<ItemId>_<UUID>.mkv The local HTTP server responds to Vimu with an HTTP 302 redirect whose Location header contains the original, unmodified Emby playback URL, including its original query parameters and authentication information. Therefore the actual media request ultimately reaches Emby exactly as originally generated, while Vimu sees a unique last path segment for every playback invocation. The UUID is important. Using only the Emby Item ID creates a persistent filename identity in Vimu and allows Vimu's own stored resume state to compete with Emby's state. Generating a fresh filename for every playback session prevents Vimu from finding an earlier filename-based resume record. The Emby resume position is explicitly supplied to Vimu using Vimu's startfrom Intent extra. Emby stores playback position in ticks, where 10,000 ticks equal one millisecond, while Vimu expects startfrom as an integer number of milliseconds. Therefore: startfrom = PlaybackPositionTicks / 10000 The Vimu Intent also uses: forceresume = false so Vimu is not instructed to override the supplied position with its own resume decision. forcename may be populated with the Emby item's display title. This affects the title displayed by Vimu but is independent of the URI filename used by Vimu's filename-resume mechanism. Vimu is launched for result. Its returned position value is read by the Emby client and converted back into the normal Emby playback reporting flow. Emby's existing Playing/Progress/Stopped reporting can therefore update the server-side UserData normally. The resulting playback flow is: Emby Server resume position → Emby Android TV → startfrom (milliseconds) → Vimu → returned playback position → Emby playback progress/stopped reporting → Emby Server The local redirect is only an identity shim for Vimu. It does not proxy the video payload itself. After the 302 response, Vimu retrieves the media directly from the original Emby URL, so the Android client is not placed in the media data path. This was tested with Emby Server 4.10.0.40 and Vimu Media Player 12.50. The key design principle is: Emby should be the sole authority for playback position. Vimu should receive Emby's position through startfrom, return its final position to Emby, and its local filename-based resume database must not be allowed to override the server-side state. In testing, generating a new UUID-based URI alias for every playback invocation solved the cross-title/cross-session resume problem while preserving normal Emby resume synchronization. -------------- Unfortunately, I have absolutely no background in programming or in what the AI actually did, so I won't be able to provide any additional consultation. 2
gluk147 8 Posted September 25 Posted September 25 I also experimented with AI. I decompiled the Emby APK and modified the `launchMediaIntent` method. After that, I rebuilt the APK, and now the integration with ViMu works correctly. Perhaps you could add this code to the official Emby app?1.txt 2
Luke 43568 Posted October 8 Posted October 8 Hi, this has been added for Emby for Android 3.5.69. You can follow the release notes topic to get notified once that is available: Thanks. 1
vanor 4 Posted October 9 Posted October 9 Glad to hear that. One more small request: if possible, please implement this feature in the Android TV version. 1 1
