dcook 319 Posted April 14 Posted April 14 (edited) I have 2 Halloween movies: They are different movies: However Emby has them combined into 1 entry: the Halloween is the 1978 movie, the [Bluray-1080p] is actually the 2018 movie Not sure why or how this is happening? Since there is only 1 entry listing in Emby, I am unsure how to specify specific imdb ids for each movie? Strange thing is Halloween (2007) show correctly as a separate movie: Edited April 14 by dcook
Luke 43549 Posted April 14 Posted April 14 Hi, they probably have the same external ids somehow. What I would do is split them manually, and then use the identify feature on both versions once they are separated.
dcook 319 Posted April 14 Author Posted April 14 6 minutes ago, Luke said: Hi, they probably have the same external ids somehow. What I would do is split them manually, and then use the identify feature on both versions once they are separated. That is my question, how do I split them in Emby? I don't see any option to do that, there is only the drop down under the version. They are already split on the file system I tried selecting the edit metadata, but no matter which of the versions is selected, the metadata editor always shows the same 2018 file in the file path?
dcook 319 Posted April 14 Author Posted April 14 (edited) Thanks! @Lukewhy isn't this split version button up at the top near the version dropdown and all the other buttons? Could it not be added to the 3dot menu as well where all the other commands are? Edited April 14 by dcook
