EmbarkingSnow 0 Posted April 14 Posted April 14 Hi! I'm so sorry if I'm posting this in the wrong place as I haven't used a forum in a long time and while I did search I couldn't find anything that matches exactly. The issue I'm having is that while I was able to watch anime I have with OPUS audio just the other day, it seems there's been an update and now it's not working. I've so far found the best experience to be playing it via the XBOX app (I would prefer to use my LG TV + Emby app but I know they have OPUS issues and it wasn't worth the headache) but I've also tried tonight to play it via browser on my Mac (Firefox browser) and it just freezes and doesn't work. When I've had this issue before I've used the Playback Correction Button in the settings but it seems to now be missing, so unless I want to change the quality from Auto to say 720 to force it to transcode (I have the Premium Version), it won't play at all and just sits there frozen. This is not ideal as I'm generally trying to watch things at 1080 etc. Is there a way to force everything to just transcode automatically to avoid this issue? Even if the Playback Correction button is reinstalled it won't be ideal for Re:Zero for example as it plays little 2 minute skits between each episode so waiting for it to freeze on a failed direct play then forcing the transcode is really tedious. Note I'm running a docker setup on a Synology NAS. Thanks for any help and advice! Snow
EmbarkingSnow 0 Posted April 26 Author Posted April 26 Hey Luke, Just touching base to see if there's any update here / anything I can do to fix this. Thanks!
Luke 43719 Posted April 29 Posted April 29 Hi, I'm not sure why the playback correction button isn't showing, but we're about to do a new server release so once you have that, please let us know if this resolves it. Thanks.
EmbarkingSnow 0 Posted May 10 Author Posted May 10 Hey Luke, Just a quick touch base to see if there's a timeline here as I haven't really been able to use the app at all to watch anything I'd like to which is a bit disheartening. Assuming there's no timeline or it's not likely to be fixed soon is there anything you can suggest I can do to to force my files to transcode? My server can well and truly handle it so I'd be happy for it to just do that so I can get back to watching
Luke 43719 Posted May 17 Posted May 17 Hi, are are about to release both the 4.9.5 server as well as an update to the Emby Xbox app. Please let us know if either of those resolves this for you. Thanks !
