will_i_am_small 0 Posted April 14 Posted April 14 I was just playing around with the tags and the parental controls feature. If a custom tag is applied to an actor, and then that tag is set to be blocked for a certain user they are still able to search for and view that given actor. Is there a way to have this not happen and for actors to be completely hidden?
will_i_am_small 0 Posted April 14 Author Posted April 14 That explains it then. Is there a method to hide actors?
Happy2Play 9840 Posted April 14 Posted April 14 17 minutes ago, will_i_am_small said: That explains it then. Is there a method to hide actors? How would that work then as media is linked to Actors so the content would be hidden also?
will_i_am_small 0 Posted April 14 Author Posted April 14 1 minute ago, Happy2Play said: How would that work then as media is linked to Actors so the content would be hidden also? Yes, that is the reason I realised this in the first place. On a child's profile they are still able to search up Actors for any media on the whole server. So I do actually want the actor and the content hidden
pünktchen 1425 Posted April 14 Posted April 14 5 hours ago, Luke said: Hi, this doesn't apply to actors. I'd say that's a bug that was simply overlooked - just like the dozens of other bugs in the parental controls that were introduced with the major database update in Emby 4.8 but have since been fixed. I still have a working 4.8.0.13 install where people with restricted Tags are hidden from search!
will_i_am_small 0 Posted April 15 Author Posted April 15 11 minutes ago, pünktchen said: I'd say that's a bug that was simply overlooked - just like the dozens of other bugs in the parental controls that were introduced with the major database update in Emby 4.8 but have since been fixed. I still have a working 4.8.0.13 install where people with restricted Tags are hidden from search! Were you able to find a solution/work around with current versions?
pünktchen 1425 Posted April 15 Posted April 15 30 minutes ago, will_i_am_small said: Were you able to find a solution/work around with current versions? I just haven't updated it yet because of the constant new bug reports and some changes that i do not really like.
Luke 43549 Posted April 15 Posted April 15 1 hour ago, pünktchen said: I'd say that's a bug that was simply overlooked - just like the dozens of other bugs in the parental controls that were introduced with the major database update in Emby 4.8 but have since been fixed. I still have a working 4.8.0.13 install where people with restricted Tags are hidden from search! But when you visit the movie details you can still see the person.
pünktchen 1425 Posted April 15 Posted April 15 8 minutes ago, Luke said: But when you visit the movie details you can still see the person. Yes, but i did not claimed otherwise.
will_i_am_small 0 Posted April 15 Author Posted April 15 2 hours ago, Luke said: But when you visit the movie details you can still see the person. I don't mind seeing actors when the media is also visible. I just don't want Actors to be visible via the search bar when the content they are in is blocked via parental restrictions.
Luke 43549 Posted April 15 Posted April 15 37 minutes ago, will_i_am_small said: when the content they are in is blocked via parental restrictions. HI there, can you please provide a specific example? Thanks !
Happy2Play 9840 Posted April 15 Posted April 15 8 minutes ago, Luke said: HI there, can you please provide a specific example? Thanks ! Example put a block tag on Merry Madagascar Actor is still available/searchable but with no content. Only tested beta.
will_i_am_small 0 Posted April 15 Author Posted April 15 1 hour ago, Happy2Play said: Example put a block tag on Merry Madagascar Actor is still available/searchable but with no content. Only tested beta. Exact same issue I have encountered. Also note as stated above that a block tag directly on the actor does not change the outcome
will_i_am_small 0 Posted April 21 Author Posted April 21 On 15/04/2026 at 14:46, Luke said: HI there, can you please provide a specific example? Thanks ! Any potential workaround based on the photo info provided?
Luke 43549 Posted April 25 Posted April 25 On 4/15/2026 at 12:58 AM, Happy2Play said: Example put a block tag on Merry Madagascar Actor is still available/searchable but with no content. Only tested beta. The problem is that when you're searching the entire database, to evaluate every single condition can cause search to perform slowly. That is why as a compromise, search is only looking at main library access with respect to people.
will_i_am_small 0 Posted April 25 Author Posted April 25 1 hour ago, Luke said: The problem is that when you're searching the entire database, to evaluate every single condition can cause search to perform slowly. That is why as a compromise, search is only looking at main library access with respect to people. Could i turn off person search overall as an alternate, or it just is how it is
Luke 43549 Posted May 10 Posted May 10 On 4/25/2026 at 2:17 AM, will_i_am_small said: Could i turn off person search overall as an alternate, or it just is how it is Yes that could be an option as well.
will_i_am_small 0 Posted May 11 Author Posted May 11 10 hours ago, Luke said: Yes that could be an option as well. Is this an option that exists already or just a potential solution?
Luke 43549 Posted May 17 Posted May 17 On 5/11/2026 at 12:12 AM, will_i_am_small said: Is this an option that exists already or just a potential solution? The option is not already there but it's something that could be added.
