emby-vainfo and emby-clinfo segfault due to LD_LIBRARY_PATH overriding system libraries
Fedora 43
emby-server 4.10.0.8
The wrapper scripts /opt/emby-server/bin/emby-vainfo and /opt/emby-server/bin/emby-clinfo crash because they set:
LD_LIBRARY_PATH=/opt/emby-server/lib:/opt/emby-server/extra/lib
Reproduction as emby user:
sudo -u emby env -i /opt/emby-server/extra/bin/vainfo
  -> works
sudo -u emby env -i LD_LIBRARY_PATH=/opt/emby-server/lib:/opt/emby-server/extra/lib /opt/emby-server/extra/bin/vainfo
  -> segmentation fault
sudo -u emby env -i /opt/emby-server/extra/bin/clinfo
  -> runs
sudo -u emby env -i LD_LIBRARY_PATH=/opt/emby-server/lib:/opt/emby-server/extra/lib /opt/emby-server/extra/bin/clinfo
This indicates the crash is caused by Emby’s bundled libraries forced by LD_LIBRARY_PATH, not by the system VA-API/OpenCL stack.
