Subtitles not showing on Android for an mkv during playback
Hey @sa2000
got the beta app installed. I will go to the old files and test it shortly but I saw another issue. For one of the Anime it wasn't showing subtitles. I reset the app (both data and cache). I rebooted Nvidia Shield TV as well. I thought maybe file has an issue and played it on plex and subtitles show as expected. Tried multiple times to no avail. Here are the logs from the server and the app.
embyserver (1).txt emby_android_1774663823627.txt emby_android_1774663131769.txt
Thanks for all the tests
Was this subttle issue for this episode file?
Fate+strange Fake - s01e01 - The Heroic Spirit Incident - WEBDL-1080p-Kaleido-subs.mkv
would it be possible to get the file for me to try and refer to the development team? If it would be ok, I can send you an upload link
And is this a regression from the earlier version ?
UsamaWaheed
Hey @sa2000for sure. Please send me the link and I can upload the file.
This is a new file so not sure if it's a regression but another file for which subtitles were working it didn't work on this. Planning on reverting to older version.
link sent
File uploaded!
I remember it had multiple subtitles. none of them worked. The one i really need is the full subtitles and it doesn't work.
  • Thanks 1
My initial tests on a Samsung phone running Emby for Android 3.5.31 and Emby Server 4.10.0.8 shows the subtitles
Thus was the selected subtitle stream
and playback does show subtitles
I will next try on an Nvidia Shield
Hey..I just tested on my mobile (Google Pixel 10 Pro Fold) with 3.5.28
Same scene no subtitles.
Can you check if it's direct play or transcoding. If I transcoder the subtitles immediately show up but direct play isn't showing it.
Also my server 4.9 - could that have anything to do with it?
  • Thanks 1
you are abolsutely right.
I will refer the issue to the development team.
Edited by sa2000
sa2000
@UsamaWaheed Initial feedback: This is suspected to be due to the compression on the embedded ASS subtitle stream and the way Exoplayer is setup within the android app.
MediaInfo
Text #1
Format                                   : ASS
Muxing mode                              : zlib
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Duration                                 : 24 min 39 s
Bit rate                                 : 80.6 kb/s
Frame rate                               : 9.353 FPS
Count of elements                        : 13842
Compression mode                         : Lossless
Stream size                              : 14.2 MiB (1%)
Title                                    : Full Subtitles [Kaleido-subs]
Language                                 : English
Default                                  : Yes
Forced                                   : No
At this moment it is only possible to play an mkv like this with transcoding to uncompress the subtitle stream and show the text
I have opened an issue on this for Emby android app development team
Edited by sa2000
