Q-Droid 1006 Posted 1 hour ago Posted 1 hour ago Is it time to explore this either in Emby core or as a plug-in if possible? https://letsencrypt.org/2026/01/15/6day-and-ip-general-availability Quote Short-lived and IP address certificates are now generally available from Let’s Encrypt. These certificates are valid for 160 hours, just over six days. In order to get a short-lived certificate subscribers simply need to select the ‘shortlived’ certificate profile in their ACME client. 1 1
Neminem 1617 Posted 49 minutes ago Posted 49 minutes ago That sounds interesting, not that I need it. But is sounds a lot like DDNS + Cert.
Q-Droid 1006 Posted 33 minutes ago Author Posted 33 minutes ago (edited) 18 minutes ago, Neminem said: That sounds interesting, not that I need it. But is sounds a lot like DDNS + Cert. These are IP based certificates which eliminate the need for domains. I should rephrase: They eliminate the requirement of a domain name. Domain names still good but not needed. Edited 29 minutes ago by Q-Droid 1
Neminem 1617 Posted 32 minutes ago Posted 32 minutes ago That sound really nice . Thanks for the explanation
