stevewalison 1 Posted 3 hours ago Posted 3 hours ago I have live racing replay media which is not available in the normal "SXXEXX" or similar format, but is named "YYYY Round XX". Currently, I duplicate the content for tracking in emby which is renamed and spread across multiple folders for different series. I then keep another clean copy of the content for seeding. If we could provide a custom regex string for specific folders, series, or libraries for custom name handling of content, I could easily provide emby with the information on handling the content. Similarly, the regex string could also allow a single folder to have multiple separate TV Shows. For example Pre-Race show, Race and Post-Race show. For example, the content might be available in the following folder format: - 2026 AMA Supercross Rd 11 Detroit 1080p60 x265.mkv - 2026 AMA Supercross Rd 11 Detroit Post Show 1080p60 x265.mkv For the main race content, I could just a regex pattern below which provides season and episode as named groups, and would only get the race. 20(?'season'\d\d) AMA Supercross Rd (?'episode'[\d]+)( [a-zA-Z]+){1,2}(?:Post Show(*FAIL)|) [0-9p]+ x26[45] For post race content, a separate regex pattern for the series could be done which forces pattern matching for the post show. 20(?'season'\d\d) AMA Supercross Rd (?'episode'[\d]+)( [a-zA-Z]+){1,2} (Post Show) [0-9p]+ x26[45] This is one example, but other content might be 4-6 different races throughout the event with unique naming and tags. I was thinking each pattern could be added similar to adding "Folders" but each Regex pattern creates a separate TV series with all of the matches. Each regex pattern would scan all of the content in the indicated folders to build up the series database. Thanks,
Solution ebr 16325 Posted 2 hours ago Solution Posted 2 hours ago Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at: 1
