Argent 0 Posted December 1, 2014 Posted December 1, 2014 (edited) Ever since the last update (client (2.1.05) and server (3.0.5445.6)) I can no longer connect to my Server via the app (over local network) I can still connect via cellular (dyndns) - but that doesn't help me when I'm sitting at home trying to stream stuff. I have three different android devices (tablet,phone, HDMI stick) and they all exhibit the same problem. When I try to connect to my servers local IP address it takes about a minute then says Server unreachable. I can however on the same devices connect to the web version of Media Browser - so I know that parts working. Edited December 1, 2014 by Argent
Redshirt 1487 Posted December 1, 2014 Posted December 1, 2014 Can you post both a client and server log showing a LAN connection attempt. Client logs are are located in \SDCard\Mb3AndroidData\Logs
Argent 0 Posted December 2, 2014 Author Posted December 2, 2014 Here's one off my phone..... https://drive.google.com/file/d/0B_bbwABrqTBlUnVDVndzSHN4V0k/view?usp=sharing and a clean one from the server taken just now after I tried to connect with my tablet https://drive.google.com/file/d/0B_bbwABrqTBlMDc1VDlvTXZyYXM/view?usp=sharing Hope this helps....
SShubbar 0 Posted December 2, 2014 Posted December 2, 2014 Greetings, I have a media browser server that works; I can connect to it on my local network. However, my domain that I need to use to access it remotely points to a reverse proxy. The proxy redirects any traffic coming to http://<domain>.org/mediabrowser (port 80) to <server IP>:4041 The server is accessable via the domain using a webbrowser, which leads me to conclude that the problem lies in the app. An identical setup is used for a madsonic server (/madsonic) which plays nicely with DSub.
Luke 42243 Posted December 3, 2014 Posted December 3, 2014 Yea hang tight folks. we will have a fix out asap.
Redshirt 1487 Posted December 3, 2014 Posted December 3, 2014 Have you added port 80 as the external port in the server dashboard
Argent 0 Posted December 3, 2014 Author Posted December 3, 2014 Have you added port 80 as the external port in the server dashboard Should I? Everything worked fine before the recent updates....now I can't connect via LAN
Redshirt 1487 Posted December 3, 2014 Posted December 3, 2014 No, sorry. That was directed at the post directly above. We're still looking into what might be causing the LAN connection issue.
Argent 0 Posted December 4, 2014 Author Posted December 4, 2014 Yea hang tight folks. we will have a fix out asap. Oh good - so I'm not crazy then I patiently await a fix!
wex101 12 Posted December 4, 2014 Posted December 4, 2014 Seconds this! Thank goodness for this thread I was getting so frustrated thinking it was just me
Argent 0 Posted December 11, 2014 Author Posted December 11, 2014 any update.....err um....to an update to fix this?
Redshirt 1487 Posted December 11, 2014 Posted December 11, 2014 I'm pretty sure we're at the tail end of testing the connection fixes. But just to give us some breathing room, let's say by the end of the weekend
Redshirt 1487 Posted December 16, 2014 Posted December 16, 2014 an 11th hour issue was discovered. I've just pushed another beta to my test team. I'm hopeful this is the one.
Argent 0 Posted December 16, 2014 Author Posted December 16, 2014 Whatever you fixed in the last beta that went out Saturday or whatever seemed to have fixed my problem - my tablet found my server locally and I was able to cast to my Chromecast It would be nice to see Media Browser be able to cast to my Xbox One directly - but I can start another topic for that if you'd like. I know my Synology NAS app (DS Video) that I was using to watch my media while this was being fixed could send to my Xbox One - so I'm guessing it might not be too difficult to get Media Browser to do it too. Keep up the great work though! Media Browser certainly has made my life happier!
Luke 42243 Posted April 24, 2017 Posted April 24, 2017 Hi, we've pushed changes to our Chromecast receiver to enable HDMI-CEC control. Please try it out. Thanks !
