jareddej 0 Posted 3 hours ago Posted 3 hours ago Hi Luke, Reviving this thread - I have issues accessing my server remotely sometimes, when accessed from a TV app or phone app it sometimes refuses to connect, and will just happen to start working 5 or so minutes later, but not always the case. It is running on a windows 10 PC, connecting via emby connect only. I have the pc set to always on and never sleep, I use Parsec to remote into the computer and each time it is up and running just fine & will end up working on the remote app access after a few minutes being on the Parsec connection. Is this an issue with Windows? Would it be easier to transition to linux? Also, side note, I found a bug where while the TV app could not connect it defaulted to the server select screen, I accidentally "removed this server" and was unable to re-add the server with emby connect or direct connect. I was forced to remove the user from my server and re-add them and their email address, it then worked as expected. I see this as a bug and want to report it! Also also, if I were to upload a log file, which one would that be? the embyserver.txt? Thank you, Jared
jareddej 0 Posted 2 hours ago Author Posted 2 hours ago Attached is logs. From reading other posts I see it could be described as the server is unresponsive to users some time after authenticating. embyserver.txt
