tedfroop21 89 Posted March 10 Posted March 10 Actors are looked up successfully. Bio and picture meta downloaded. Have to open actor by clicking on picture, then refresh and actor shows, no other lookup required.
visproduction 338 Posted March 10 Posted March 10 TF, This is a known issue and I believe it has to do with a bandwidth limit of the site supplying actors photos. For this, I believe, is a free service, each user gets only so many lookups per minute. Second part is that if and when there is any delay because te server giving the actor's images is busy with 1000 other requests or whatever, then the image might eventually arrive after the media page is fully loaded. There is no automatic reload and test the page every minute on Emby, that would drag down the whole site. You can force a page refresh and probably pick up the missing Actors headshots that way. I don't think there is a way around this delay without dragging down the overall speed of the page loads. 1
Luke 42287 Posted March 12 Posted March 12 HI, try refreshing the metadata on the series and see if that helps. 1
