MediaEmby1968 56 Posted 2 hours ago Posted 2 hours ago Thank you, this update makes it look fantastic! 1
Aleas 41 Posted 1 hour ago Author Posted 1 hour ago (edited) 2 hours ago, MediaEmby1968 said: Thank you, this update makes it look fantastic! You are most welcome. Also, I discovered a tiny bug, and looking at your screenshot you seem to prefer the blue colors. So, I had a little fun, I think you might enjoy this option. Updates: Fix table hover backgrounds (was using user accent theme colors) New Option: you can say nope to the gold and have everything use a user accent color. Look for this option in the variables: Being easter I didn't have time to fully test it, but on the surface it looks good. /* --- CUSTOM MASTER PALETTE --- */ /* OPTION 1 - USE THE THEMES GOLD COLOR */ --my-gold: rgb(var(--my-gold-rgb)); /* Solid gold fallback for borders and text accents */ --my-gold-light: rgb(var(--my-gold-light-rgb)); /* Brighter gold fallback for highlight gradients */ --retro-navy: rgb(var(--navy-base-rgb)); /* Darkest navy fallback for main backgrounds */ --retro-navy-light: rgb(var(--navy-mid-rgb)); /* Mid-tone navy fallback for panels and cards */ /* OPTION 2 - USE THE USERS ACCENT COLOR PREFERENCES */ /* --my-gold: hsl(var(--theme-primary-color-hue, 204), var(--theme-primary-color-saturation, 100%), var(--theme-primary-color-lightness, 50%)); /* --my-gold-light: color-mix(in srgb, var(--my-gold) 70%, white); /* Solid gold fallback for borders and text accents */ /* --retro-navy: rgb(var(--navy-base-rgb)); /* Brighter gold fallback for highlight gradients */ /* --retro-navy-light: rgb(var(--navy-mid-rgb)); /* Mid-tone navy fallback for panels and cards */ Maybe we should harass Luke now to add in more accent colors Emby Navy and Gold v4.60.css Edited 42 minutes ago by Aleas 1
