Belenkiy 2 Posted March 9 Posted March 9 Hi! I’m running Emby Server on Synology (DSM7.3.2 , package, x86_64). I’m trying to fix a long-standing issue: library scans hang and sometimes artwork doesn’t load / UI feels stalled. Environment Device: Synology NAS (DSM 7.3.2-86009 update 1), volume is Btrfs (/volume1) Emby Server: 4.9.3.0, (also tested 10.0.4 and 10.0.5version, issue persists) ProgramData: /var/packages/EmbyServer/var → symlink to /volume1/@appdata/EmbyServer Libraries: TV: /volume1/video/Serials Movies: /volume1/video/Movies Symptoms “Scan media library” hangs Logs stop showing “next step” as if the previous step was successful but the next one did not start: In logs Emby completes some scan steps, then no further “start next step” entries appear for a long time, while server still shows “Scan media library” running. What I already checked / tried File system is fast; find /volume1/video/Serials -type f completes quickly. Permissions: ProgramData cache/metadata folders are owned by emby:emby; emby user can write to them (su emby -c touch ... OK). Removed local NFO files temporarily and disabled NFO metadata reader to avoid broken/empty NFO overriding online metadata. Disabled UPnP mapping in Emby (auto port mapping) to prevent external influence. Questions Any recommended diagnostics to identify where the scan is blocked (e.g. enabling debug for TaskManager / library scanner)? embyserver.txt logs around scan start and the hang point Thanks! embyserver.txt
