markdj 49 Posted March 8 Posted March 8 Hi, I'm not sure if this is a real Kodi or Emby issue, but the Kodi log tells me if has to do with Emby (as far as I can tell) so that's why I'm posting it here. But the video starts stuttering shortly after starting a series or movie, and later it starts to stutter so severely that there's no choice but to stop the video entirely. Could someone maybe please take a look at this? This log contains some stutter around the 21:07 mark. I'll try to post a log later when it gets to the extreme part. I think Emby is trying to communicate with the server and things take a turn there? https://paste.kodi.tv/qibizinoza.kodi
visproduction 335 Posted March 8 Posted March 8 (edited) Guessing original media is too heavy for your server settings to handle everything at once. EAC3 8 channels 4K, 60 fps and multiple .ass subs. Try online test videos in 4K and see if they work. Try adjusting your transcoding and direct play settings. lines 613 to 639 Quote 2026-03-08 21:02:20.263 T:22442 info <general>: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through) 2026-03-08 21:02:20.266 T:21743 info <general>: CActiveAESink::OpenSink - initialize sink 2026-03-08 21:02:20.266 T:21743 info <general>: Trying to open: samplerate: 48000, channelMask: 12, encoding: 4 2026-03-08 21:02:20.359 T:21743 info <general>: Minimum size we need for stream: 12320 Bytes 2026-03-08 21:02:20.359 T:21743 info <general>: Audiotrack buffer params are: period time = 32.083 ms, period size = 12320 bytes, num periods = 4 2026-03-08 21:02:20.359 T:21743 info <general>: Created Audiotrackbuffer with playing time of 128.333333 ms min buffer size: 49280 bytes 2026-03-08 21:02:20.550 T:21743 info <general>: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 48000 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 49280 m_frames: 1540 m_frameSize: 8 channels: 2 2026-03-08 21:02:20.662 T:21834 info <general>: EMBY.hooks.player: [ onAVChange ] 2026-03-08 21:02:21.025 T:21725 info <general>: Instancing CRendererMediaCodecSurface 2026-03-08 21:02:21.025 T:21725 info <general>: CRendererMediaCodecSurface::Configure 2026-03-08 21:02:21.061 T:21834 info <general>: EMBY.hooks.player: [ onAVChange ] 2026-03-08 21:02:21.061 T:21834 info <general>: EMBY.hooks.player: --> [ onAVStarted ] 2026-03-08 21:02:21.072 T:21834 info <general>: EMBY.helper.playerops: [ GetPlayerInfo ] 2026-03-08 21:02:21.072 T:21834 info <general>: EMBY.hooks.player: [ Queue playing item ] 2026-03-08 21:02:21.114 T:21834 info <general>: EMBY.hooks.player: --< [ onAVStarted ] 2026-03-08 21:02:21.178 T:21725 info <general>: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY 2026-03-08 21:02:21.191 T:21725 info <general>: [WHITELIST] Searching the whitelist for: width: 3840, height: 2160, fps: 25.000, 3D: false 2026-03-08 21:02:21.195 T:21725 info <general>: Display resolution ADJUST : 3840x2160 @ 59.940060 - Full Screen (16) (weight: 0.000) 2026-03-08 21:02:21.261 T:21834 info <general>: EMBY.hooks.player: [ onAVChange ] 2026-03-08 21:02:21.650 T:21860 info <general>: EMBY.hooks.websocket: [ UserDataChanged ] [{'PlayedPercentage': 44.54740288424935, 'PlaybackPositionTicks': 15903160000, 'PlayCount': 3, 'IsFavorite': False, 'LastPlayedDate': '2026-03-08T20:02:22.0000000Z', 'Played': False, 'ItemId': '318068'}] 2026-03-08 21:02:21.746 T:21860 info <general>: EMBY.hooks.websocket: UserDataChanged skip by ItemSkipUpdate / Id: 318068 / ItemSkipUpdate: ['318068', 'KODI318068', '318068'] 2026-03-08 21:03:28.005 T:22437 warning <general>: OutputPicture - timeout waiting for buffer 2026-03-08 21:03:38.193 T:22747 info <general>: EMBY.hooks.websocket: THREAD: --->[ Emby server is busy, sync in progress ] 2026-03-08 21:03:48.214 T:22747 info <general>: EMBY.hooks.websocket: THREAD: ---<[ Emby server is busy, sync in progress ] 2026-03-08 21:04:18.039 T:21860 info <general>: EMBY.hooks.websocket: [ LibraryChanged ] {'FoldersAddedTo': [], 'FoldersRemovedFrom': ['100786'], 'ItemsAdded': [], 'ItemsRemoved': ['251000'], 'ItemsUpdated': [], 'CollectionFolders': [], 'IsEmpty': False} 2026-03-08 21:04:18.065 T:22796 info <general>: EMBY.database.library: Worker_is_paused: worker_remove / {'server_starting_9769a5d86cfe4385814e11c87d95a9cf': False, 'database_init_9769a5d86cfe4385814e11c87d95a9cf': False, 'priority': False, 'kodi_rw': False, 'playerbusy': False, 'playing': True, 'server_busy_9769a5d86cfe4385814e11c87d95a9cf': False} 2026-03-08 21:04:18.065 T:22796 info <general>: EMBY.database.library: -->[ open_Worker delay: Worker_is_paused ] Edited March 8 by visproduction
ebr 16331 Posted March 8 Posted March 8 You are using Kodi for playback, not our Android/Android TV app?
markdj 49 Posted March 8 Author Posted March 8 That is correct. I'm using the Emby add-on to sync the library but play everything through Kodi.
markdj 49 Posted March 9 Author Posted March 9 I'm not sure because everytime I see a stutter it seems Emby is trying to interact with something. But I can't be sure. Can't upload any full logs anywhere, because they get absolutely massive, so here's a part where a stutter happened at 15:46. kodi.log
markdj 49 Posted March 13 Author Posted March 13 Hi, yes, there's still stutter in the videos, though not as extreme as in the original post.
markdj 49 Posted March 14 Author Posted March 14 (edited) This is a partial log of a stutter just now (at 22:46): " 2026-03-14 22:46:04.358 Info PlaystateService-0HNK075FQ06NV:00000989: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:46:04.358 Info PlaystateService-0HNK075FQ06NV:00000989: http/1.1 Response 204 to host7. Time: 1ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. 2026-03-14 22:46:14.366 Info PlaystateService-0HNK075FQ06NV:0000098C: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:46:14.366 Info PlaystateService-0HNK075FQ06NV:0000098C: http/1.1 Response 204 to host7. Time: 1ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. 2026-03-14 22:46:24.380 Info PlaystateService-0HNK075FQ06NV:00000990: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:46:24.380 Info PlaystateService-0HNK075FQ06NV:00000990: http/1.1 Response 204 to host7. Time: 1ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. 2026-03-14 22:46:34.389 Info PlaystateService-0HNK075FQ06NV:00000993: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:46:34.389 Info PlaystateService-0HNK075FQ06NV:00000993: http/1.1 Response 204 to host7. Time: 0ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. 2026-03-14 22:46:36.471 Info App: ValidatePhysicalRoots completed validating 100787 Series F:\Extracted\Series 2026-03-14 22:46:36.471 Info App: ValidatePhysicalRoots start validating 160140 Series Z:\Series 2026-03-14 22:46:36.988 Info App: ValidatePhysicalRoots completed validating 160140 Series Z:\Series 2026-03-14 22:46:36.988 Info App: ValidatePhysicalRoots start validating 281715 Series F:\Series 2026-03-14 22:46:37.023 Info App: ValidatePhysicalRoots completed validating 281715 Series F:\Series 2026-03-14 22:46:37.023 Info App: ValidatePhysicalRoots start validating 230558 userplaylists C:\Users\mark_\AppData\Roaming\Emby-Server\programdata\data\userplaylists 2026-03-14 22:46:37.028 Info App: ValidatePhysicalRoots completed validating 230558 userplaylists C:\Users\mark_\AppData\Roaming\Emby-Server\programdata\data\userplaylists 2026-03-14 22:46:37.028 Info App: ValidateTopLibraryFolders validating 99825 Movies 2026-03-14 22:46:37.028 Info App: ValidateTopLibraryFolders validating 100789 TV shows 2026-03-14 22:46:37.028 Info App: ValidateTopLibraryFolders validating 104041 Collections 2026-03-14 22:46:37.028 Info App: ValidateTopLibraryFolders validating 127120 Playlists 2026-03-14 22:46:44.397 Info PlaystateService-0HNK075FQ06NV:00000997: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:46:44.398 Info PlaystateService-0HNK075FQ06NV:00000997: http/1.1 Response 204 to host7. Time: 1ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. 2026-03-14 22:46:54.409 Info PlaystateService-0HNK075FQ06NV:0000099A: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:46:54.410 Info PlaystateService-0HNK075FQ06NV:0000099A: http/1.1 Response 204 to host7. Time: 1ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. 2026-03-14 22:47:04.418 Info PlaystateService-0HNK075FQ06NV:0000099E: http/1.1 POST http://192.168.2.22:8096/Sessions/Playing/Progress. Source Ip: host7, UserAgent: Emby for Kodi Next Gen/11.1.27 2026-03-14 22:47:04.418 Info PlaystateService-0HNK075FQ06NV:0000099E: http/1.1 Response 204 to host7. Time: 1ms. POST http://192.168.2.22:8096/Sessions/Playing/Progress. " The only thing I see in the Emby Server log where something of activity happens and when the stutter occurs. I also checked the Kodi log file (without debug though, mind you), but there didn't seem to be anything happening there. Looks like Emby is trying to validate A LOT of things. How can I decrease this, or better yet: fix it? Edited March 14 by markdj
markdj 49 Posted March 15 Author Posted March 15 (edited) Or maybe a delay until after playback? Why is it validating so many files in the first place? Is it a code for something or is it actually somehow validating 127 thousand playlists? I also have a kodi log of a recent movie that I can send by PM if needed. Edited March 15 by markdj
Luke 42233 Posted March 23 Posted March 23 Did you have a library scan run at that time? Could the resource consumption from that be a problem?
