ZanderKeen 73 Posted March 8 Posted March 8 (edited) Issue: After creating a custom playlist and adding a movie more than once, the movie fails to show duplicated within the playlist order on apple tvos devices. It only shows up once in the first position of the playlist when it was added. However the playlist does show the movie duplicated/added more than once on the web version. Server version: Stable 4.9.3.0 TVOS version: 2.0.3.2 Apple TV model: A1842 Server Logs: irrelevant To reproduce: Create a custom playlist, add several movies while repeating one of the movies in particular more than one time (in my case, every other movie with a random movie between it). Open the custom playlist and each movie seems to only appear once in the first order position it is added. Expected Results: The movie added again as a duplicate to a playlist is expected to be repeated in the custom playlist, like it does on the web version. Actual Results: Movie only displays once per-playlist on apple tvos. Priority: Low @SamES Edited March 8 by ZanderKeen
ZanderKeen 73 Posted March 8 Author Posted March 8 (edited) Update to this bug, after further testing it seems to be only an issue within the UI not displaying the duplicated items. I have managed to leave one of the playlists play and it does in fact play the duplicated movie as every-other movie like I have set. It just doesn't display that movie more than once visually in the playlist lineup order list. Edited March 8 by ZanderKeen 1
