esmailelbob 1 Posted March 7 Posted March 7 I have an Emby media server where storage is attached via rclone mount. The backend is served through an app called Altmount (similar concept to nzbdav). My goal is to get movies to start playing in 1 second or less. Currently there's a noticeable delay on first play before Emby can start streaming the file. I tried kodi for emby and with webdav and webdav was noticeably faster so is there anyway or config that i can use in rclone to overcome this emby headings and make it faster? My rclone setujp is: ``` rclone: path: /config password: "" salt: "" rc_enabled: true rc_url: "" rc_port: 5573 rc_user: admin rc_pass: admin rc_options: {} mount_enabled: true vfs_name: altmount mount_options: {} log_level: ERROR uid: 1000 gid: 1000 umask: "002" buffer_size: 32M attr_timeout: 5s transfers: 32 cache_dir: /config/cache vfs_cache_mode: full vfs_cache_poll_interval: 10s vfs_read_chunk_size: 32M vfs_cache_max_size: 100G vfs_cache_max_age: 8760h read_chunk_size: 32M read_chunk_size_limit: 2G vfs_read_ahead: 2G dir_cache_time: 5s vfs_cache_min_free_space: 1G vfs_disk_space_total: 1G vfs_read_chunk_streams: 4 allow_other: true allow_non_empty: true read_only: false timeout: 1h syslog: true no_mod_time: true no_checksum: true async_read: true vfs_fast_fingerprint: true use_mmap: true links: false ```
bunty_sam 0 Posted March 8 Posted March 8 (edited) I had similar slow start-up issue, I have mounted my seedbox to my home server and play from it. This is my setting, you might need to change the names in it. With this setting its working fine for months, no delay in stream response. What my settings below does is mounts the seedbox, which is a WebDAV mount, I also have a cache directory setup so that rewinds are faster and its kept for 7 days, so within 7 days if same content is played then there will not be any need to stream from the seedbox again, it will play locally. You will need to use your user name, group name, mount location, rclone mount name to customise it for yourself. I think this will solve your issue. Persistent Rclone Seedbox Mounting through WebDAV automation [Unit] Description=Rclone Mount for Seedbox (Jellyfin Optimized) After=network-online.target Wants=network-online.target StartLimitIntervalSec=60 StartLimitBurst=5 [Service] Type=simple User=bunty Group=bunty ExecStart=/usr/bin/rclone mount Seedbox-WebDAV:/ /mnt/Seedbox \ --config=/home/bunty/.config/rclone/rclone.conf \ --vfs-cache-mode=full \ --cache-dir=/media/bunty/CCL-1TB/rclone-cache \ --vfs-cache-max-size=500G \ --vfs-cache-max-age=168h \ --dir-cache-time=1h \ --vfs-read-chunk-size=16M \ --vfs-read-chunk-size-limit=1G \ --vfs-read-ahead=128M \ --buffer-size=128M \ --transfers=8 \ --checkers=8 \ --allow-other \ --umask=002 \ --uid=1000 \ --gid=1000 \ --log-file=/home/bunty/rclone-mount.log \ --log-level=INFO ExecStop=-/bin/fusermount -uz /mnt/Seedbox Restart=on-failure RestartSec=10 LimitNOFILE=65536 TimeoutStopSec=20 [Install] WantedBy=multi-user.target Save the file as rclone-seedbox.service in /etc/systemd/system/ sudo systemctl daemon-reload sudo systemctl enable rclone-seedbox.service sudo systemctl restart rclone-seedbox.service sudo systemctl status rclone-seedbox.service --no-pager if everything goes alright then you will see something like this, and then you restart the emby container or the server itself and see if stream start-up time is fixed Edited March 8 by bunty_sam
kikinjo 294 Posted March 8 Posted March 8 You need to optimize rclone mount. You have many settings that are not needed at all, chunk reading and others. keep it simple and use only --buffer-size=64M \
esmailelbob 1 Posted March 8 Author Posted March 8 30 minutes ago, bunty_sam said: I had similar slow start-up issue, I have mounted my seedbox to my home server and play from it. This is my setting, you might need to change the names in it. With this setting its working fine for months, no delay in stream response. What my settings below does is mounts the seedbox, which is a WebDAV mount, I also have a cache directory setup so that rewinds are faster and its kept for 7 days, so within 7 days if same content is played then there will not be any need to stream from the seedbox again, it will play locally. You will need to use your user name, group name, mount location, rclone mount name to customise it for yourself. I think this will solve your issue. Persistent Rclone Seedbox Mounting through WebDAV automation [Unit] Description=Rclone Mount for Seedbox (Jellyfin Optimized) After=network-online.target Wants=network-online.target StartLimitIntervalSec=60 StartLimitBurst=5 [Service] Type=simple User=bunty Group=bunty ExecStart=/usr/bin/rclone mount Seedbox-WebDAV:/ /mnt/Seedbox \ --config=/home/bunty/.config/rclone/rclone.conf \ --vfs-cache-mode=full \ --cache-dir=/media/bunty/CCL-1TB/rclone-cache \ --vfs-cache-max-size=500G \ --vfs-cache-max-age=168h \ --dir-cache-time=1h \ --vfs-read-chunk-size=16M \ --vfs-read-chunk-size-limit=1G \ --vfs-read-ahead=128M \ --buffer-size=128M \ --transfers=8 \ --checkers=8 \ --allow-other \ --umask=002 \ --uid=1000 \ --gid=1000 \ --log-file=/home/bunty/rclone-mount.log \ --log-level=INFO ExecStop=-/bin/fusermount -uz /mnt/Seedbox Restart=on-failure RestartSec=10 LimitNOFILE=65536 TimeoutStopSec=20 [Install] WantedBy=multi-user.target Save the file as rclone-seedbox.service in /etc/systemd/system/ sudo systemctl daemon-reload sudo systemctl enable rclone-seedbox.service sudo systemctl restart rclone-seedbox.service sudo systemctl status rclone-seedbox.service --no-pager if everything goes alright then you will see something like this, and then you restart the emby container or the server itself and see if stream start-up time is fixed It took me 2-3s but mostly 2s, can we get lower?
bunty_sam 0 Posted March 8 Posted March 8 3 minutes ago, esmailelbob said: It took me 2-3s but mostly 2s, can we get lower? I was happy with 2-3s so I don't know if it's possible to lower it further, but I think it depends on the transfer rate. Though, the cached files will start playing instantly since they are available locally.
esmailelbob 1 Posted March 8 Author Posted March 8 22 minutes ago, kikinjo said: You need to optimize rclone mount. You have many settings that are not needed at all, chunk reading and others. keep it simple and use only --buffer-size=64M \ I tested it wtih: rclone: path: /config password: "" salt: "" rc_enabled: true rc_url: "" rc_port: 5573 rc_user: admin rc_pass: admin rc_options: {} mount_enabled: true vfs_name: altmount mount_options: {} # Set to INFO temporarily per Bunty's setup to verify it works, can change to ERROR later log_level: INFO # Permissions uid: 1000 gid: 1000 umask: "002" allow_other: true allow_non_empty: true read_only: false # ========================================== # BUNTY'S CACHE SETTINGS # ========================================== vfs_cache_mode: full cache_dir: /config/cache vfs_cache_max_size: 100G # Kept your 100G limit vfs_cache_max_age: 168h # Bunty's 7 days (168 hours) vfs_cache_poll_interval: 10s vfs_cache_min_free_space: 1G vfs_disk_space_total: 1G # ========================================== # BUNTY'S BUFFER & CHUNK SETTINGS # ========================================== buffer_size: 64M # Bunty uses a large RAM buffer vfs_read_chunk_size: 16M # Bunty's sweet-spot for WebDAV TTFB vfs_read_chunk_size_limit: 1G # Caps exponential growth vfs_read_ahead: 128M # Bunty's balanced read-ahead vfs_read_chunk_streams: 4 # ========================================== # BUNTY'S METADATA / DIR CACHE # ========================================== dir_cache_time: 1h # Bunty's 1-hour directory cache attr_timeout: 1h # Matching dir_cache_time # ========================================== # BUNTY'S NETWORK SETTINGS # ========================================== transfers: 8 checkers: 8 timeout: 1h # ========================================== # SYSTEM TWEAKS (Kept from your setup) # ========================================== syslog: true no_mod_time: true no_checksum: true async_read: true vfs_fast_fingerprint: true use_mmap: true links: false but still same results 2-3s
esmailelbob 1 Posted March 8 Author Posted March 8 13 hours ago, esmailelbob said: I have an Emby media server where storage is attached via rclone mount. The backend is served through an app called Altmount (similar concept to nzbdav). My goal is to get movies to start playing in 1 second or less. Currently there's a noticeable delay on first play before Emby can start streaming the file. I tried kodi for emby and with webdav and webdav was noticeably faster so is there anyway or config that i can use in rclone to overcome this emby headings and make it faster? My rclone setujp is: ``` rclone: path: /config password: "" salt: "" rc_enabled: true rc_url: "" rc_port: 5573 rc_user: admin rc_pass: admin rc_options: {} mount_enabled: true vfs_name: altmount mount_options: {} log_level: ERROR uid: 1000 gid: 1000 umask: "002" buffer_size: 32M attr_timeout: 5s transfers: 32 cache_dir: /config/cache vfs_cache_mode: full vfs_cache_poll_interval: 10s vfs_read_chunk_size: 32M vfs_cache_max_size: 100G vfs_cache_max_age: 8760h read_chunk_size: 32M read_chunk_size_limit: 2G vfs_read_ahead: 2G dir_cache_time: 5s vfs_cache_min_free_space: 1G vfs_disk_space_total: 1G vfs_read_chunk_streams: 4 allow_other: true allow_non_empty: true read_only: false timeout: 1h syslog: true no_mod_time: true no_checksum: true async_read: true vfs_fast_fingerprint: true use_mmap: true links: false ``` I tried to run locally and it was still slow 7s to startup Also I ran commands to Bypass Rclone & Emby # Clear caches first! curl -u usenet:[pass] \ -r 0-2000000 \ -o /dev/null \ -s -w "TTFB (Altmount + Usenet): %{time_starttransfer} seconds\n" \ "http://localhost:8080/webdav/movies/Forrest.Gump.1994.REMASTERED.1080p.BluRay.X264-AMIABLE/Forrest.Gump.1994.REMASTERED.1080p.BluRay.X264-AMIABLE.mkv" and ran to Bypass Emby # Clear caches first! time head -c 2000000 /mnt/altmount/movies/Forrest.Gump.1994.REMASTERED.1080p.BluRay.X264-AMIABLE/Forrest.Gump.1994.REMASTERED.1080p.BluRay.X264-AMIABLE.mkv > /dev/null and borth results are: TTFB (Altmount + Usenet): 0.000000 seconds and real 0m0.007s user 0m0.000s sys 0m0.004s so I'm not sure anymore what cause the 2s thing
esmailelbob 1 Posted March 8 Author Posted March 8 6 hours ago, bunty_sam said: I was happy with 2-3s so I don't know if it's possible to lower it further, but I think it depends on the transfer rate. Though, the cached files will start playing instantly since they are available locally. yeah seems like it, no matter what i try and i cant break 2s. thank you for sharing config tho
esmailelbob 1 Posted March 12 Author Posted March 12 4 hours ago, Luke said: Please let us know if you find anything. Thanks. To be honest I did not find it yet, It seem random too like some movies start after 2s and some take over 5s so yeah.... 1
