kaledi 42 Posted March 5 Posted March 5 Has something changed with emby as I've just tried a few hybrid hdr10+/dv mkv files and they play fine. Previously, you'd get the pink screen. Anyone know what has changed?
kaledi 42 Posted March 6 Author Posted March 6 Wow, great work. Thought it was a limitation of the device.
kaledi 42 Posted March 6 Author Posted March 6 Is there any chance now that you've solved the playback of these hybrid files, you can provide a way to select which hdr format to play?
Luke 42243 Posted March 6 Posted March 6 I would try it but we haven’t specifically looked at that. 1
kaledi 42 Posted March 6 Author Posted March 6 Think I've discovered a bug. When connected to a multi channel receiver and a file with multi channel audio is selected, on initial play it plays in stereo. If you select an alternative audio track it play correctly and that is the case if you move back to the original audio track. Also it cna be 'corrected' by selecting a lower quality that forces a conversion
Luke 42243 Posted March 6 Posted March 6 1 minute ago, kaledi said: Think I've discovered a bug. When connected to a multi channel receiver and a file with multi channel audio is selected, on initial play it plays in stereo. If you select an alternative audio track it play correctly and that is the case if you move back to the original audio track. Also it cna be 'corrected' by selecting a lower quality that forces a conversion Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
