martincom 29 Posted March 5 Posted March 5 I'm having two guide issues: 1. WTVM Columbus, GA virtual channels 9.1 and 9.10: We receive guide data for WTVM-ABC, virtual channel 9.1, as expected. However, this channel's signal strength is poor and most of the time it is unwatchable. WTVM broadcasts the identical programming on virtual channel 9.10, via low power translator WCGZ-LD, which has a much stronger signal due to its close proximity to us. This allows us to not only view it, but reliably record from Emby. However, we cannot schedule recordings from virtual channel 9.10 as there is no guide data for it. I see two possible remedies: The guide data service provides listings for virtual channel 9.10, WCGZ-LD which are identical to virtual channel 9.1,WTVM. Would there be some method within Emby to overlay the guide from virtual channel 9.1 to 9.10? 2. The same low power translator, WCGZ-LD, also broadcasts three sub-channels: Virtual channel 47.2, Telemundo Virtual channel 47.3, Peachtree Sports Network Virtual channel 47.4, Outlaw Of interest to us is virtual channel 47.4, Outlaw (westerns channel) there is no guide data being provided for this channel. We'd very much like to see guide data provided for it.
sa2000 695 Posted March 5 Posted March 5 (edited) @martincomWhat is the Guide Lineup identifier ? You will see that in Live TV Server Settings setup tab. It will be in the form of USA-xxxxx-DEFAULT Gracenote do not normally include low power stations in their lineups. I need to know zip code/lineup identifier to start looking and also what TV market does your area come under. I see these markets listed for Alabama on https://www.rabbitears.info/ Birmingham, Alabama Mobile, Alabama untsville, Alabama Montgomery, Alabama Dothan, Alabama Edited March 5 by sa2000
martincom 29 Posted March 5 Author Posted March 5 37 minutes ago, sa2000 said: @martincomWhat is the Guide Lineup identifier ? USA-OTA36801, I had included it in the title of the thread. I need to know zip code 36855 what TV market does your area come under. Columbus, GA I had included that in the thread title, also. 1
sa2000 695 Posted March 5 Posted March 5 5 hours ago, martincom said: Would there be some method within Emby to overlay the guide from virtual channel 9.1 to 9.10? I am looking into the issue - but you should be able to circumvent the problem. In Live TV Settings, Channels tab Do not map 9.1 to any guide data For tuner channel 9.10, map it to guide data for USA-OTA36801 to guide channel 9.1 (I see that the lineup for zip code 36855 - USA-OTA36855 does not list any of the 9.x and 47.x channels - but USA-OTA36801 has 9.1 to 9.6. I will ask gracenote to look into adding 9.10 - assuming they do have WCGZ-LD1 in their database)
sa2000 695 Posted March 5 Posted March 5 There is inconsistency in available channel info for 36801 and 36855 For Example info for USA 36855 here https://www.channelmaster.com/pages/tv-antenna-map-five-points-al-36855 lists these as available for 9.x and 47.x 9.10 WCGZ-LD1 ABC 47.2 WCGZ-LD2 TELEMUND 47.3 WCGZ-LD3 APSN 47.4 WCGZ-LD4 OUTLAW and for USA 36801 zip code here https://www.channelmaster.com/pages/tv-antenna-map-opelika-al-36801 , it lists 9.1 to 9.7 but not 9.10 and no 47.x channels Normally I give gracenote evidence of a channel being available for a zip code from the channelmaster.com data As it stands, if I refer to gracenote, it would need to be adding 9.10 and 47.x channels to the USA-OTA36855 lineup rather than USA-OTA36801
martincom 29 Posted March 5 Author Posted March 5 We're about equal distant from Atlanta and Columbus, GA. Occasionally, we also have reception for the Birmingham stations. So when I set this up three years ago, I installed three guide data sources: USA 36801, USA 30301 & USA 35005. In this manner, I would guide data for all the channels we received, even though a number were inconsistently. It was three years ago, but I'm thinking I left USA 36855 out intentionally because of overlap. I utilized 36801 instead. I can't remember the specific issue that drove me to utilize 36801, but it wouldn't be an issue for to change to 36855. USA 36863 maybe a better fit, however.
sa2000 695 Posted March 6 Posted March 6 Thanks. I have submitted a request to Gracenote to add channels to USA-OTA36855 and USA-OTA3683 for 9.x and 47.x channels listed on: https://www.channelmaster.com/pages/tv-antenna-map-five-points-al-36855 and https://www.channelmaster.com/pages/tv-antenna-map-lanett-al-36863 I have indicated that the priority one is 9.10 WCGZ-LD1 ABC
martincom 29 Posted March 6 Author Posted March 6 Thank you! The work-around you detailed in post #6 has resolved the issue for now. 1
sa2000 695 Posted March 10 Posted March 10 On 06/03/2026 at 12:56, martincom said: The work-around you detailed in post #6 has resolved the issue for now. I am afraid that this will need to stay as the circumvention for the problem. Gracenote have responded that 9.10 WCGZ-LD1 is out of scope for their lineups - which would be the case when the station is not in their database. WCGZ would need to ask gracenote themselves, to include it in the lineups
martincom 29 Posted March 10 Author Posted March 10 I understand and very much so appreciate the effort you put into this. If only all software was supported as well as Emby is. You guys are the gold standard. 1 1
