tmurphy2792
So I'm pretty sure I've made a similar FR a long while back that Luke had said they'd add to the development list. (Iirc, human readable name field to accompany RSS feed URL to make it easier to manage it.) But on further thought today, it would make much more sense to enable management from the main UI inside the library.
For example if an admin user is in the podcast library, they can right click/long touch/3 dots to open the options menu on a particular podcast. In that menu they should be able to "Delete" a podcast to have the appropriate RSS URL removed from the list. Or "Edit Metadata" window should have a field with the RSS URL so that you can update it if necessary.
I listen to a lot of podcasts, and often if someone suggests a new one or I hear about one that sounds potentially interesting, I will give it a try. But I've found my podcast list getting crowded with ones I don't listen to. It would be a massive chore to go find which generic megaphone.fm/buzzsprout/libsyn URL belongs to which podcast.
Quote
Hi, yes, this is something that we're interested in for future updates. Thanks.
