Problems reading music video clips with Samsung
Go to solution Solved by SamES,
Tandhruil
When reading music video on Samsung TV the image quality is poor. I thought it was the original recording but I played the same videos on a androidtv app and the video was clean. Looking at the logs it seems there is a problem playing the videos.
Samsung TQ55Q73D
MN : TQ55Q73DATXXC
PD : 3/8/2025
SN : 0LWY3HFY100335F
FW : T-PTMLDDEUC-1301.0
FC : SWU-OU_T-PTMLDDEUC_1301_241206
The Emby app is up to date
The video are copied with yt-dlp yt-dlp.exe -P "D:\VIDEO\Clips" -f "bv[height<=720]+ba/b" --remux-video mp4 https://www.youtube.com/watch?v=%1"
thanks
logs.zip
  • Solution
SamES
We've had a lot of issue with Opus audio with mixed results, so we removed the support for Direct Playing opus audio.  This should be causing an audio conversion and HLS streaming, but the avi video format needs to be converted as it's not supported in HLS streaming, so it's falling back to a full transcode.
It also looks like there are issues converting the video format which is probably causing the quality issues.
Can you try disabling Hardware acceleration/decoders and test with software conversion?
Since you are already doing a conversion when you download, could you try also transcoding the audio to aac at the same time?
  • Thanks 1
Tandhruil
Thank you for the answer. Effectively, I've no more ffmpeg logs with aac sound videos.
I tried different formats on the samsung tv and an android device and add the logs to this message :
1 webm container and AV1 + OPUS codecs
2 mp4 container and AV1 + OPUS codecs
3 mp4 container and H264 + AAC codex
For information, if the codec change but the file isn't update in the database, emby still believe its the previous codec and try to transcode it (4th test). Emby samsung client doesn't check the codecs of the file.
but it seems there is still troubles between emby an samsungTV device (see embyserver.txt logs of 06/03/2026)
If needed I can join the video files to
4tests.zip embyserver.txt
SamES
Yes, if you replace the file you need to manually execute a Metadata Refresh on that file.
Can you repeat just the test with 'mp4 container and H264 + AAC codex' after a metadata refresh and confirm the results and post any logs from this test.
Or wait for the next library scan.
Tandhruil
Here are the logs
The file is remux.mp4 dicovered in DV1+Opus in mp4 container
Played once then replaced by H264+AAC in mp4 container (no update) played again, then metadata updated and played one lat time.
But image is still poorer on Smasung TV than on an adroid tablet on the same local WiFi
logs.zip
SamES
Can you please try playback again with just the last test with the newfile and the metadata updated, and turn on stats for nerds on the tv during playback and send a picture of the details?  Please also let me know what that playback quality looks like
Tandhruil
Well, I guess we will stop here, I can't make screen-shot from the TV and I can say I have no more ffmpeg alarms since I've changed the codecs
  • Thanks 1
SamES
So is the picture quality OK now? A photo would be fine, but I am correct that Stats for Nerds now only says DirectPlay as the playback method?
