gillmacca01
1st screenshot of tuner page
2nd screenshot of programme info
3rd screenshot: mapping
sa2000
Thank you  - list becomes
402 - SSPOPL   - Sky Sports Premiere League (schedule references 502)
404 - SSPOCR   - Sky Sports Cricket (schedule references 505)
406 - SSPOF1   - Sky Sports F1 (schedule references 507)
408 - SSPOAC   - Sky Sports Action/NFL (schedule references 510)
417 - TNTSP3VM - BT Sports 3 (schedule references 529)
The channel numbers issue I think is less important as users can match them manually. So I will refer the issue with the schedules for these first
  • Thanks 1
adrianlovell
@sa2000Also for your reference, the internet streamed Sky Glass/Sky Stream have a different channel numbers vs. the Satellite Sky Q version. (helpful isn't it!)  I believe this thread is about the Sky Q satellite EPG.
The Sky Glass / Sky Stream EPG channel list is here: TV channels list on Sky Glass and Sky Stream | Sky Help | Sky.com | Sky Help | Sky.com
For SkyQ this list looks correct to me: List of channels on Sky Q (United Kingdom & Ireland) – TVCL – TV Channel Lists
sa2000
2 hours ago, adrianlovell said:
Yes - I found this web site and I used it to compare and ask gracenote to get the channel numbrs checked out for Sky Q. Not found an official Sky.com web page listing the Sky Q channels. Their changes web page does mention satellite channel numbers relating to the changes and I presume these would be Sky Q channel numbers - but for Sky Sports channels, only the rebadging for 412 to be Sky Sports Action is mentioned.
These are the discrepancies I found between the Sky Q lineup for West and the list on the TVCL page. I asked gracenote to look into them
Edited by sa2000
  • Like 1
gillmacca01
Well so far they have removed sky Sports Cricket from the lineup and that is all
sa2000
I questioned the removal - rather than change the channel. They have corrected the logo for 113 Sky One but not added an entry for it at 106
They also removed 408 Sky Sports Action
Maybe the updates are iterative - removals and then additions later
gillmacca01
Looks like they have gone through the entire guide and corrected things - a lot of channels needed remapping.
Although one channel is now missing that was there before. Channel 970 - BBC Red Button
gillmacca01
321 Great Mystery maps but no listing.
There were listings prior
adrianlovell
They do have one, but unfortunately it’s accessible to subscribers only. Checking those on your list just now:
Sky Sports Cricket: 405
Sky Sports Golf: 406
Sky Sports F1: 407
Sky Sports Tennis: 408
Sky Sports Action: 412
Sky Sports Arena: Does not exist, but I have Sky Sports+ on 404
TNT Sports 3: 413
TNT Sports 4: 414
Racing TV: 424
TNT Sports Ultimate: I don’t have this on the EPG I’m afraid
  • Thanks 1
sa2000
Thanks for checking @adrianlovell -  these agree with I had in the "Should it be?" column above
I just checked the latest Sky Q (West) lineup GBR-1007536-DEFAULT and it has had a big update
They have corrected the sky sports channels mentioned above and also put 106 Sky One.  @gillmacca01
gillmacca01
All the Sports channels are sorted now..thanks
Just missing listings for channel 321 great mystery and channel 970 BBC Red Button (both mapped)
sa2000
Yes - The Sky Sports schedules for these have been corrected
Sky Sport Premier League	402		"callSign": "SPLHD"
Sky Sports Cricket		405		"callSign": "SSPOCRH"
Sky Sports F1			407		"callSign": "SKYSF1HD"
Sky Sports Action		412		"callSign": "SSPOACD"
TNT Sports 3			413		"callSign": "TNTSPO3HD"
I still see one wrong schedule but it is on SD channel for TNT Sports 3 on 874
I have reported these to Gracenote. You say both mapped but I can no longer see 970 in the lineup for Sky Q West
Edited by sa2000
gillmacca01
It was there yesterday, but gone now
sa2000
321 Great Mystery has been fixed
sa2000
Sorry - just double checking. They switched the internal ID. I need to check if it has a schedule
sa2000
There is a quirk ! The lineup still has the old ID's for 321 as well as the new ID's. So until they remove the old references, make sure 321 is mapped to the 321 lineup entry with callsign GRETMYS and not GREATMY
gillmacca01
Confirmed great mystery now has listings
Thanks
Edited by gillmacca01
  • Thanks 1
sa2000
970 for BBC Red Button should be ok
I am seeing a lot of duplication of channel numbers in the latest version of the Sky Q (West) lineup - don't know what the impact is yet. I have mentioned this to gracenote. 117 channels have double entries with different callsigns
gillmacca01
Just did a refresh and cannot see 970.
Also not seeing these duplicates my end
gillmacca01
BBC Red button now available with listings.
Thanks for you help with these issues. Much appreciated
  • Thanks 2
