Make Card background transparent for custom icons in 4.10.03
Go to solution Solved by Luke,
Mobius
I have been using the old Emby for windows ver 3.0.20 with some custom icons.There was an issue where the card background shows (offputting to me), which I was able to remedy with the old winstyles.css.The card background was made transparent so all was good. It also allows the icons to be closer together so they all fit in a single row.Otherwise I end up with 2 rows, so bonus.
With the new MS store version 4.10.0.3 it's back to looking odd and my icons scroll to take up 2 rows. So I could use some help.
Is there a CSS script I can put into the  'Server settings' of 4.10.0.3 that will give me the same appearance as with 3.0.20?
version 4.10.0.3 looks like this
I want it to look the way I had it in 3.0.20 which is this
Cheers in advance. :)
  • Solution
Hi, there is currently no way to control this in the windows app, but more options are possible for future updates. Thanks.
Mobius
OK, thanks for the quick reply. Much appreciated!.
I assume you mean "no way to control this in the windows app" also means there is no 'config file' of sorts that you can edit and/or point to a custom css?
I was hoping that like my current workaround with 3.0.20, ('filesystem.js'  requires 'windowstyle.css'), that it would be relatively simple.
I'm not a coder though.
Hi, yes that is correct.
