rbjtech 5345 Posted February 25 Posted February 25 7 minutes ago, fabien_m2002 said: Thanks for your help! - The folder view of the libary is not the trick. It scans only the primary folder. - the UHD folder is well recognised even it's not followed the rule Industry (2020) [UHD]/ (i can see the 2 versions in the drop doan list version) I think it's a limitation of Emby, maybe a new feature to develop? The only way is to watch only in FHD version Split the versions, scan the files - and then re-group them. It's a workaround, but it will work. 2
