Samsng phoone and Samsung DEX + XREL Glasses - no controls
mmhorda
Hi. Anyone uses Emby on Samsung phone with DEX + Xreal Glasses?
I  cannot control the video when a movies starts. Once it is on DEX mode and phone screen acts as a touchpad. if i touch the screen then no controls appearing :(
Is there any known workaround or fix?
mmhorda
Is there anybody to check this out from Emby team? i mean to confirm or reject the issue at least? :) I can help with testing.
mmhorda
Is anyone using Samsung DEX + XR Glasses. There are no controls when watching videos. does the android app even support mous/touchpad?
The thing is that with XR glasses phone becomes a touchpad, and there is no way to bring the media controls when tapping on the screen.
mmhorda
I kinda found out what the problem is. If i use external player feature and chose mpv then everyting is working as expected.
It seems like something is broken for external monitors with emby media player because those glasses are in fact external monitors over USB-C
Hi, we are looking into this. Thanks.
  • Like 1
TigerBeanst
Hi Luke, can you check this too?
I don't know if they are the same problem.
