ExtremeTM 1 Posted February 12 Posted February 12 With Plex having destroyed the Home page from the 'new experience' in all apps but Android TV. And in anticipation of the eventual Android rollout, I've been looking at Emby as a replacement for it, and for Channels DVR which I use exclusively for DVR, TV and TVE. I've got Emby running on my Synology NAS (version 4.9.3.0-724090300) and on Android TV (version 2.1.23g). I'm wanting to upgrade to Premier but have this issue with trailers. None work for TV or Movies. I get the same error every time. This video is unavailable. Error code: 152-4. I'm logged into YouTube. I also run Jellyfin and the trailers work fine. Although, I'm not planning on keeping Jellyfin. Unless I can fix this, it's pretty much a deal breaker. I've looked in the posts and haven't found a solution although many experience this issue. Any ideas how to fix this?
Abobader 3482 Posted February 12 Posted February 12 Hello ExtremeTM, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution ebr 16304 Posted February 12 Solution Posted February 12 Hi. Sign up for the Google beta for that app (Android TV) or search for just "Emby for Android" in the play store and both will play the trailers fine. https://play.google.com/apps/testing/tv.emby.embyatv 1
ExtremeTM 1 Posted February 12 Author Posted February 12 It worked! Thanks for the lightning fast support. 1
