CharlieB 1 Posted February 8 Posted February 8 Hi I have Emby on a Fire TV Stick 4K Max (2nd Gen) running Emby for Android 3.5.28 but it can't play various HEVC files without getting into a strange slow mo judder. Emby Server is showing it as Direct Play for Video and Direct Play for Audio, with no embedded subtitles Any ideas how I can fix this please? Thanks in advance VIDEO STREAM ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 42 min Bit rate : 2 000 kb/s Width : 1 920 pixels Height : 816 pixels Display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.053 Stream size : 1.43 GiB (90%) AUDIO STREAM ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 1 h 42 min Bit rate mode : Constant Bit rate : 224 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 164 MiB (10%) Language : English Default : Yes
Luke 42243 Posted February 11 Posted February 11 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
