Betonhaus 18 Posted February 8 Posted February 8 Right now when adding an Emby server to a client you have to type out the full address including http:// or https://, and if you are using a proxy you have to manually change the port to 80/443. That can cause confusion when you're trying to get family set up on the server. Meanwhile on jellyfin if you enter myserver.com it'll automatically check all four configurations and use the one that gets a response. Would it be possible to set it up that when adding a server you can just enter mysite.com and it'll automatically check http://mysite.com:8096, https://mysite.com:8920, http://mysite.com:80, and http://mysite.com:443 and then pick the one that works? 2 1
Solution ebr 16335 Posted February 8 Solution Posted February 8 11 hours ago, Betonhaus said: automatically check http://mysite.com:8096, https://mysite.com:8920, https://mysite.com:80, and http://mysite.com:443 But, not in that order, right? I think we would want to try the two https options first... Related: 1
