HammyShawn 1 Posted February 7 Posted February 7 I use Emby on Roku, and no matter what I do, when I go into any of my folders, it defaults to the "Tags" section at the top. I have all of my defaults set to "Folder" in the settings, so I am not sure why it does not follow that logic. I have young children that want to watch cartoons, and they do not know how to change it from "Tags" to "Folders." I have reinstalled the Emby app on my Rokus to make sure that was not the issue. I have also switched the defaults off of Folders and then put it back to Folders. Any ideas?
Solution ebr 16332 Posted February 7 Solution Posted February 7 Hi. Please click on the "cog" icon in the top right of the library you are in and select your default tab.
HammyShawn 1 Posted February 8 Author Posted February 8 Thanks a bunch. I looked everywhere except for that exact spot while inside of the folder. 1
