EdBarnes 3 Posted February 6 Posted February 6 It would be nice if you could save the subtitle offset per episode/movie once you find the correct setting. It is a great feature that you can set the offset but once the correct value is found the viewer should be able to save it back to the server for future lookup. Would be nice if the saved value was automatically applied when the show is watched again rather than having to lookup and reload it. 1
rbjtech 5341 Posted February 6 Posted February 6 Agree it would be nice to do in Emby, but once you know the value to + or -, something like Subtitle Edit will allow you to do that with a few clicks. Emby has never messed with the source file - so for embedded subs, I highly doubt this would be implemeted, but I don't see any reason why it could not be extracted and written to an external sub file and then made the default sub.
ebr 16335 Posted February 6 Posted February 6 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
