[BUG] In TV mode, the function to adjust playback speed by long-pressing the “OK” button does not work.
Hello, I'm using the latest Emby Universal App 3.5.28 on a Shield TV 2017.
I learned from this post so that long pressing the OK button during playback will pull up the playback speed menu that on Emby for TV, you can now quickly access playback speed options by long-pressing the “OK” button.
However, after testing, this option doesn't work.
As shown in the video, I configured the long press of the “OK” button to trigger “Playback Speed.” Yet when I open a movie and hold down the ‘OK’ button, the “Playback Speed” menu does not appear. Only the playback controls show up. I've tried this multiple times with the same result.
Therefore, I can confirm this feature is not working.
You can test it on your TV, and you'll see what I mean.
Please fix this bug in the next version. Thank you!
Edited by chuwz
Is playback speed in the gear menu?
Hello, the options are in the gear menu.
  • 3 weeks later...
OK we'll take a look at this. Thanks.
Okay, thank you very much. I hope you can fix this problem as soon as possible.
  • Thanks 1
