mhutchison 5 Posted February 2 Posted February 2 After nuking and reinstalling my server 10s of times within the past couple of months with different IP addresses and ports, I decided to uninstall all Emby apps from my TV and devices and start fresh. I had held off updating the Emby app recently because I had to login to my LG account. My Shield does most of the heavy lifting anyway. But, on my C1, I swear Dolby Vision worked just fine before this latest update. Did it ever work? Or was I just lucky because I also have auto update off? I just read multiple posts from a couple years ago about this very problem. This just a sanity check because I swear it worked. I know nothing can be done. On the latest beta as well.
Luke 42233 Posted February 3 Posted February 3 Hi, Dolby vision in mkv's was working up until recently when an LG software update removed it. Now it has to be mp4. Hopefully this will be restored in an upcoming WebOS update.
mhutchison 5 Posted February 3 Author Posted February 3 2 minutes ago, Luke said: Hi, Dolby vision in mkv's was working up until recently when an LG software update removed it. Now it has to be mp4. Hopefully this will be restored in an upcoming WebOS update. Thanks Luke. I just wanted to confirm. Patiently waiting to know what you think on my other issue. Thanks for all your hard work. 1
