soderlund 103 Posted March 4 Author Posted March 4 1 minute ago, crusher11 said: @soderlund91the plugin image should probably be updated. It is updated, not sure what it still sticks.. Might be browser or server cache? For me its updated, but i have uninstalled, reinstalled and so on a few times while testing.
soderlund 103 Posted March 4 Author Posted March 4 (edited) WARNING! I just made a run with the "sync home screen" and all of my homescreen sections for the source user got deleted. I'm gonna look into this as soon as possible (will be tomorrow). Make sure to backup both the plugin AND Emby (user settings). It could be because i selected the source user in the "copy to". Not sure. EDIT: Yeah, that's it. DO NOT COPY TO THE SOURCE USER !! I'm gonna add a function that prevents this Edited March 4 by soderlund91
Jdiesel 1435 Posted March 4 Posted March 4 58 minutes ago, soderlund91 said: Nothing really. Well, to be true, I don't know how to do it. It's something I have been thinking about aswell. It will happen sooner or later I hope https://github.com/MediaBrowser/Emby/wiki/Getting-your-plug-in-in-the-catalog 1
crusher11 1134 Posted March 4 Posted March 4 @soderlund91The top row, where you select between Tag & Collection, Home Screen, and Settings, is white text on a white background for the unselected options. I just happened to hover over one and it turned grey. 1
soderlund 103 Posted March 5 Author Posted March 5 21 minutes ago, soderlund91 said: WARNING! I just made a run with the "sync home screen" and all of my homescreen sections for the source user got deleted. I'm gonna look into this as soon as possible (will be tomorrow). Make sure to backup both the plugin AND Emby (user settings). It could be because i selected the source user in the "copy to". Not sure. EDIT: Yeah, that's it. DO NOT COPY TO THE SOURCE USER !! I'm gonna add a function that prevents this Made a quick fix and put out v3.0.0.1. Updated the previous post with new .dll and also on github 1 minute ago, crusher11 said: @soderlund91The top row, where you select between Tag & Collection, Home Screen, and Settings, is white text on a white background for the unselected options. I just happened to hover over one and it turned grey. Thanks for reporting!
seanbuff 1353 Posted March 5 Posted March 5 When I download 3.0.0.1 from GH link: https://github.com/soderlund91/HomeScreenCompanion/releases/tag/v3.0.0.1 It loads in Emby as 3.0.0.0 still Even the .dll version info on the file says 3.0.0.0 Did it not get updated correctly?
soderlund 103 Posted March 5 Author Posted March 5 (edited) 5 hours ago, seanbuff said: When I download 3.0.0.1 from GH link: https://github.com/soderlund91/HomeScreenCompanion/releases/tag/v3.0.0.1 It loads in Emby as 3.0.0.0 still Even the .dll version info on the file says 3.0.0.0 Did it not get updated correctly? Probably my mistake.. It was like almost 2am I was pretty tired and stressed trying to get that fix out Best way to test is by navigating to the Home Screen settings in the plugin and check if the selected user in source user is grayed out in the “sync to” section. If so, you have the latest update. Not sure why this happened.. I rebuilt the .dll with no changes to the code and now it works. Thanks for reporting! Edit: Updated the dll on github and attached here aswell. No real need to update if it work as above. I'm gonna put out another bugfix later today/tonight with the reported bug for light theme where the menu doesnt show. HomeScreenCompanion.dll Edited March 5 by soderlund91 1
chander421 17 Posted March 5 Posted March 5 Thank you so much for this great update. What a long way we've come since the first release! We are now very close to finally having real smart playlists in Emby. If I may say so, it seems to me that there are just a few parameters missing to be able to create truly comprehensive smart playlists: date added (& date modified), file size, and played (last played). Thanks again for this superb plugin!
antoniopulido98 1 Posted March 5 Posted March 5 Could you please provide the dll of the new version for macOS using net 6 as you did the last time if it’s not too much of a hassle? after testing the previous version all works fine
soderlund 103 Posted March 5 Author Posted March 5 3 hours ago, chander421 said: Thank you so much for this great update. What a long way we've come since the first release! We are now very close to finally having real smart playlists in Emby. If I may say so, it seems to me that there are just a few parameters missing to be able to create truly comprehensive smart playlists: date added (& date modified), file size, and played (last played). Thanks again for this superb plugin! Thank you so much for the kind words! Just help me out with what filter you want and I'll get it in there. 1 hour ago, antoniopulido98 said: Could you please provide the dll of the new version for macOS using net 6 as you did the last time if it’s not too much of a hassle? after testing the previous version all works fine Will do, sorry that i forgot about it. I'm curently working on the next update and i'll make sure to build a .net v6 for that! 1
soderlund 103 Posted March 5 Author Posted March 5 (edited) I know i promised that i would get an update out with a fix for the light theme (menu not visible). I got carried away when working on the plugin so I ended up building in some big improvements aswell. So it might take another day or two until next release with that fix, just use dark theme until then if its a big issue. Sorry about the trouble, but... Teaser for next release. Now we can manage each users home screen sections directly from the plugin. We can move the sections and adjust the order. This function is completed and works like a charm! Curently working on a way to create a home screen section directly from the Tag and Collection menu. So when we create an entry for a tag or collection, there will be an option to also create a home screen section for this entry and select what users to give it to. Next step is then to adjust order (with the function above) for one user, and then copy it to all others. All this could possibly be automated aswell. If i can get this working, it will be a HUGE improvement from Embys native way of doing this at the moment. Edited March 5 by soderlund91 3
Jdiesel 1435 Posted March 5 Posted March 5 One thing that I've been dreaming for is generation of playlists based on playcounts or watchtime for all users on the server. Things like "Most watched this week/month" "Or Tending on his sever" types of playlists. There is another project Aperture that does this already and the Dev does plan to include some feature that Home Screen Companion already has. There is something nice about having a native plugin like HSC to keep things simple. Anyways I'm not aware of a way to track playcounts and playtime across users natively in Emby. All current solutions manage this through a secondary database. It would be amazing if HSC had a way to tie into though existing metrics to levage user data. Potential options: Utilize the Playback Reporting plugin database https://github.com/faush01/playback_reporting Access stats Jellystat via its API https://github.com/CyferShepard/Jellystat Access stats through Tracerr via its API https://github.com/connorgallopo/Tracearr Have HSC collect stats and manage its on db
soderlund 103 Posted March 5 Author Posted March 5 22 minutes ago, Jdiesel said: One thing that I've been dreaming for is generation of playlists based on playcounts or watchtime for all users on the server. Things like "Most watched this week/month" "Or Tending on his sever" types of playlists. There is another project Aperture that does this already and the Dev does plan to include some feature that Home Screen Companion already has. There is something nice about having a native plugin like HSC to keep things simple. Anyways I'm not aware of a way to track playcounts and playtime across users natively in Emby. All current solutions manage this through a secondary database. It would be amazing if HSC had a way to tie into though existing metrics to levage user data. Potential options: Utilize the Playback Reporting plugin database https://github.com/faush01/playback_reporting Access stats Jellystat via its API https://github.com/CyferShepard/Jellystat Access stats through Tracerr via its API https://github.com/connorgallopo/Tracearr Have HSC collect stats and manage its on db I don't want to say no, but.. Maybe down the line, we will se. I'm having another kid on the way so not sure how much time i will have in the future for big improvements. I'm surely not gonna develop at this rapid pace as I have been doing for the last weeks, damn I have put down almost all my free hours on this for the last month It started out with a simple script and then i thought, "wouldn't it be nice to make this into a plugin?". So yeah, I don't want to say no, but not right now. If you can, pls create an issue at the github page. It's a lot easier to keep track of everything then https://github.com/soderlund91/HomeScreenCompanion/issues 1
shinedou 7 Posted March 6 Posted March 6 @soderlund91do you currently use the Smart Playlists 2.0 plug-in? I was just wondering if you were familiar with the type of rules (filtering) it provides? My guess is you probably aren't wanting to mimic it's filtering options but it may give you some ideas what folks are interested in.
chander421 17 Posted March 6 Posted March 6 10 hours ago, soderlund91 said: Thank you so much for the kind words! Just help me out with what filter you want and I'll get it in there. Just Date Added (& Date Modified if possible), file size, and Played (Last Played/Watched). Using these filters and the others already included in your plugin, it would be possible to completely replace Emby playlists like "Latest Media" & "Recently Released". Smart Playlists 2.0 have those, just in case ^^. Thanks! 1
soderlund 103 Posted March 6 Author Posted March 6 Beta release - Version 3.1.0.0-beta Download .dll and release notes: https://github.com/soderlund91/HomeScreenCompanion/releases/tag/v3.1.0.0-beta This release contains big improvements of home screen section handling. Use at own risk, I have tested the basic functionality but need your help to fully test, hence a BETA release. Please report any bugs or issues at the GitHub-page or here in the forum. Note Make sure to back up your settings before updating, just in case. Both the plugin and Emby (user data) Note Included a .NET V6 release, this is for legacy use (mostly for MacOS). This version is NOT tested. New Section management: Added function to manage a users home screen sections. You can now reorder sections directly from the plugin itself Create home screen sections: Added ability to create a new home screen section directly when creating a tag or collection. Improvements Created a flag for tag and home screen section in the header of each entry. Removed the source counter to make room. Fixes Bug fix: Fixed an issue when menu was not visible in light theme HomeScreenCompanion.dll HomeScreenCompanion_NET6_MacOS.dll 1 1
szymonSamsung 0 Posted March 6 Posted March 6 (edited) I tried to tinker with it a little everything works without any issues for now, might there also be a possibility to sync library order ? Edited March 6 by szymonSamsung
LongMan 116 Posted March 6 Posted March 6 17 hours ago, Jdiesel said: Anyways I'm not aware of a way to track playcounts and playtime across users natively in Emby. All current solutions manage this through a secondary database. It would be amazing if HSC had a way to tie into though existing metrics to levage user data. Smart Playlists 2.0 allows filtering by playcount. I think its implementation is quite good. It allows you to select which users to use in calculating playcount in the filters. The only improvement I would request is adding All Users so that it is a bit easier to select a server wide filter. 2
crusher11 1134 Posted March 6 Posted March 6 (edited) On 3/2/2026 at 3:45 AM, crusher11 said: @soderlund91The genre matching seems to be for partial matches, while cast is an exact match? I tried creating one for the genre “Black” and it pulled in the genres “Blackmail” and “Black Ops” as well. I tested to see if a Robert Downey cast rule would pull in both Sr. and Jr., but it actually pulled in neither. @soderlund91Have you looked at this? I tried an IMDB ID rule and entered nm0001647, just to see what would happen, and it appears that the answer is “nothing.” Which I did kind of expect. EDIT: Also now that we have negative matching and IMDB ID matching, it would appear that the blacklist section is redundant? Edited March 6 by crusher11
soderlund 103 Posted March 6 Author Posted March 6 (edited) 17 hours ago, shinedou said: @soderlund91do you currently use the Smart Playlists 2.0 plug-in? I was just wondering if you were familiar with the type of rules (filtering) it provides? My guess is you probably aren't wanting to mimic it's filtering options but it may give you some ideas what folks are interested in. I have it installed but not using it that much. But yeah, I don’t want to create a copy of it but I can certainly get some inspiration from it 3 hours ago, szymonSamsung said: I tried to tinker with it a little everything works without any issues for now, might there also be a possibility to sync library order ? Nice, thanks for testing! That helps me a lot! Sure think, I’ll look into it but shouldn’t be too hard 23 minutes ago, crusher11 said: @soderlund91Have you looked at this? I tried an IMDB ID rule and entered nm0001647, just to see what would happen, and it appears that the answer is “nothing.” Which I did kind of expect. I have forgotten about it. Will look at it for upcoming releases. I’m thinking I’ll just add a selection for “match exakt” or “partial match”. Not sure what you mean with the IMDb ID tbh It works as intended right? Edited March 6 by soderlund91
soderlund 103 Posted March 6 Author Posted March 6 Just for information, I’ll take a break from this for a few days and just enjoining the weekend. Letting you guys play and test the latest beta. I feel I have reached a milestone with the plugin and all the features I wanted to have (and more thanks to your suggestions) is there. Im gonna focus one or two releases into bug fixes and smaller improvements, then I believe this is ready for the official Emby plugin catalog. If you encounter any bugs, have any suggestions for improvements, or any feature ideas, it would help me if you post them on GitHub. It’s fine posting it here as well, but I might miss it or forget. https://github.com/soderlund91/HomeScreenCompanion/issues Thanks! 3
Aleas 31 Posted March 9 Posted March 9 Great plugin! A must have with the new spotlight stuff... Thanks for the hard work..
soderlund 103 Posted March 9 Author Posted March 9 On 3/5/2026 at 11:28 PM, Jdiesel said: One thing that I've been dreaming for is generation of playlists based on playcounts or watchtime for all users on the server. Things like "Most watched this week/month" "Or Tending on his sever" types of playlists. I'm currently working on a play count for all users, so with that you almost get what you are looking for. I might look into adding watchtime aswell. On 3/6/2026 at 8:55 AM, chander421 said: Just Date Added (& Date Modified if possible), file size, and Played (Last Played/Watched). Using these filters and the others already included in your plugin, it would be possible to completely replace Emby playlists like "Latest Media" & "Recently Released". Smart Playlists 2.0 have those, just in case ^^. Thanks! Will be in the next update On 3/6/2026 at 5:14 PM, LongMan said: Smart Playlists 2.0 allows filtering by playcount. I think its implementation is quite good. It allows you to select which users to use in calculating playcount in the filters. The only improvement I would request is adding All Users so that it is a bit easier to select a server wide filter. Working on this right now, will be in the next release. On 3/6/2026 at 6:09 PM, crusher11 said: @soderlund91 EDIT: Also now that we have negative matching and IMDB ID matching, it would appear that the blacklist section is redundant? We do still need it if you use external list for example, or local collection. 3 hours ago, Aleas said: Great plugin! A must have with the new spotlight stuff... Thanks for the hard work.. Thank you! And thanks for trying it out! 4
soderlund 103 Posted March 10 Author Posted March 10 (edited) New stable release - Version 3.1.1.0 Download .dll and full release notes: https://github.com/soderlund91/HomeScreenCompanion/releases/tag/v3.1.1.0 This release contains all features from latest beta and also improvements to mostly the smart playlist feature. Note Make sure to back up your settings before updating, just in case. Both the plugin and Emby (user data) Note Included a .NET V6 release, this is for MacOS or legacy support. This version is NOT tested. New (introduced in 3.1.0.0-beta) Section management: Added function to manage a users home screen sections. You can now reorder sections directly from the plugin itself Create home screen sections: Added ability to create a new home screen section directly when creating a tag or collection. Updates Smart playlist / local media information Added more filter for local media information Date added Date modified File size Last played (per user or all users) Watched / Unwatched (per user or all user) Play count (per user or all user) Added option for partial or exact matches fore some filters Added premade filters for local media information, to use as inspiration or examples, or of course as is. Created a function where you can save and load a set of filter Other Made the "Schedule badge" in the header standing out more when priority override is active Created a duplicate function to each entry (the copy will be placed at the top of the list) Improvements Optimization improvements using local media information Created a flag for Tag and Home screen section in the header of each entry. Removed the source counter to make room. (introduced in 3.1.0.0-beta) Updated the "Help" window Fixes Bug fix: Fixed an issue when menu was not visible in light theme (introduced in 3.1.0.0-beta) Bug fix: Fixed a bug where the UI in Home Screen --> Manage didn't show Thanks to all testers and all ideas for features! If i may say so myself this is turning out to be a pretty good plugin, and a lot of this is thanks to you guys! HomeScreenCompanion.dll HomeScreenCompanion_NET6_MacOS.dll Edited March 10 by soderlund91 Added the .dll 2
Jdiesel 1435 Posted March 11 Posted March 11 Unless I am misinterpreting the rules, I can't get the last played rule to work. What I'm trying to achieve is only show items watched by any user in the last 30 days.
