soderlund91 50 Posted yesterday at 06:40 PM Author Posted yesterday at 06:40 PM 20 minutes ago, sh0rty said: Great work! One question though: Am I able to set a poster URL for collections? If not, I propose this as a feture request @soderlund91 Currently, no. But I would say it's fairly easy to do manually by editing the pictures/metadata of the collection once it has been created. I will look into the possibility of implementing this, since a few of you have asked for it. As I'm playing and using the plugin myself, I notice some things along the way that need to improve. Currently on my to-to is: An easier way to move objects in the manual sorting. A filter option (for example, only show collections, scheduled, etc.). By request: improved collection handling — poster, description, and general metadata. Support for more sources. And a major thing I want to do — if it will be supported by the Emby API — is to add an option to create a home screen section directly from the plugin (Emby Server 4.10+). This would be a killer feature, at least for my use case. So those are my thoughts. What started with only tags might end up as an overall "home screen manager." We'll see down the road how this evolves and how much time I get, but it always good to have an ambition! 1
chander421 15 Posted 15 hours ago Posted 15 hours ago Exciting stuff! However, I think there is a problem with the exclusion of certain titles (advanced tab). As you can see here, I have blacklisted five titles, but they keep reappearing in the collection every time I sync. I have even deleted the tags and removed the movies from this collection manually, but nothing works... Any idea why?
soderlund91 50 Posted 14 hours ago Author Posted 14 hours ago 30 minutes ago, chander421 said: Exciting stuff! However, I think there is a problem with the exclusion of certain titles (advanced tab). As you can see here, I have blacklisted five titles, but they keep reappearing in the collection every time I sync. I have even deleted the tags and removed the movies from this collection manually, but nothing works... Any idea why? Yeah, the blacklist funktion seems to be broken.. Slipped through my version-testing. I'll look into it as soon as possible! Thanks for the report!
soderlund91 50 Posted 9 hours ago Author Posted 9 hours ago New release - Version 2.2.0.0. Download .dll here: https://github.com/soderlund91/AutoTag/releases/tag/v2.2.0.0 Also attached to this post New Features Filter options: Filter your list by name/search, schedule or collection Improvements & Fixes Bug fixes: Blacklist: Fixed a bug where blacklist settings didnt apply UI Updates: Merged all settings into one expandable menu Manual sorting is now drag-and-drop instead of arrows. Renamed each objects "Advanced" to "Blacklist" Other Max item: Separate by each URL. 0 now means unlimited (actually it means 10000 but in reality that equals to unlimited) Note If you don't see the changes after updating, please refresh your page and clear the browser cache. AutoTag.dll
