EmblemJD 21 Posted January 30 Posted January 30 Ever since iOS 26 hit the fan I am having a very hard time going to specific time-frames on videos and movies. I am not sure if it is an Emby issue but it is really putting a damper on usability on AppleTV and warrants having a look at. Prior I was able to navigate easily and also in fine increments - but now scrolling is almost impossible and it jumps in big chunks back and forth, making it impossible to pinpoint scenes in eg. TV series and clips of shorter runtime. It does not matter whether I use the physical remote or the one on iOS, hence I am checking also here: Anyone experiencing the same or knows a fix (or can verify if this is Emby or Apple issue)? Thanks!
alex77777 25 Posted January 30 Posted January 30 4 hours ago, EmblemJD said: Ever since iOS 26 hit the fan I am having a very hard time going to specific time-frames on videos and movies. I am not sure if it is an Emby issue but it is really putting a damper on usability on AppleTV and warrants having a look at. Prior I was able to navigate easily and also in fine increments - but now scrolling is almost impossible and it jumps in big chunks back and forth, making it impossible to pinpoint scenes in eg. TV series and clips of shorter runtime. It does not matter whether I use the physical remote or the one on iOS, hence I am checking also here: Anyone experiencing the same or knows a fix (or can verify if this is Emby or Apple issue)? Thanks! I've haven't had any issues with this from what I remember. Are you using the touch pad to fast forward and rewind? If so I believe there is a speed setting in the Apple TV settings to make the touch pad slower.
