tattler 31 Posted January 24 Posted January 24 (edited) The issue with playing too fast on Chromebook seems to be resolved. But the audio is not working for (E)AC3 and any high resolution sound except for DTS-HA MA (downmixed). AAC is working fine though. Emby seems to not be able to detect that Chromebook cannot play AC3 and should downmix the high resolution audio to either MP3 or AAC. The transcoding happens only for movie resolution but audio is not converted (downmixed) on Chromebook with the Emby for Android app. I tried with multiple movies and can confirm that only DTS-HA MA gets downmixed to AAC correctly but not other formats. Even AC3 stereo is not downmixed to MP3 or AAC. The option to convert to uncompatible audio to AC3 is not enabled. All other HD sound produces no audio at all. It seems to be in the audio capability detection that does not work. Can you take a look at this? Before this, everything was playing fine with audio and media. Something must have been changed since either in the server or the Emby app. Edited January 24 by tattler
tattler 31 Posted January 24 Author Posted January 24 That is why I said it seems... at least on the Acer Chromebook one of my family members has. The playback is normal now, only audio issues.
Luke 42241 Posted January 25 Posted January 25 14 hours ago, tattler said: That is why I said it seems... at least on the Acer Chromebook one of my family members has. The playback is normal now, only audio issues. HI, what version number of the app are you on?
Luke 42241 Posted January 29 Posted January 29 @tattler Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
tattler 31 Posted February 22 Author Posted February 22 (edited) Hi @LukeI got the logs now for Emby server and Emby for Android app on Chromebook. I am at Europe/Amsterdam timezone (CET/UTC+1). I started with the test at around 15:19. The profile name is Celine and I have attached the logs (after removing sensitive info). Only the movie Once Upon a time in China is playing correctly and the audio is converted to AAC. All other media is playing without any sound. I even turn on/off the option to convert audio to dolby digital but it does not solve the no audio issue. Let me know if you need more details to troubleshoot this issue. Thanks in advance! embyserver(3).txt hardware_detection-63907266840.txt emby_android_1771684158719.txtffmpeg-remux-64644ad7-555d-45b8-8b4d-bf7c7d6be80a_1.txt ffmpeg-remux-1a89af0b-58e5-4a84-b480-bb3c1f63dd74_1.txt ffmpeg-transcode-68aa5159-5a47-4dc4-bd57-17b3b38b96b5_1.txt ffmpeg-transcode-18814479-a2f0-4164-8e7f-ed01c3c1304b_1.txt ffmpeg-remux-97a179bc-2401-4cf7-8073-f4bec0109b1a_1.txt ffmpeg-remux-04eaec9e-2d41-4970-a3d5-98462c32edd5_1.txt ffmpeg-directstream-66974c3c-5cc6-41a3-bb07-d796ae803704_1.txt ffmpeg-directstream-74768858-077a-4652-be1a-b9ec61fa0d0a_1.txt ffmpeg-transcode-54957088-b66b-433e-93d1-c21d869320b2_1.txt ffmpeg-transcode-fc31c6b0-6ba1-4223-ba3a-1d5bded9504e_1.txt ffmpeg-directstream-2ef70f43-a32d-43af-bf29-9cd064055a9c_1.txt emby_android_1771683865995.txt Edited February 22 by tattler
visproduction 335 Posted February 22 Posted February 22 Your AC3 shows up as EAC3 Dolby Atmos in your remux log. I think Atmos is the problem. See: https://support.emby.media/support/articles/LG-Why-not-Atmos.html?q=atmos Other related dscussions on this online: https://duckduckgo.com/?q=Dolby+Digital+AC3+audio+convert+Emby&ia=web Solution may be to remux the audio to another codec and save new media verisons. I don't deal with Atmos. This is a guess. 1
tattler 31 Posted February 23 Author Posted February 23 Hi @visproductionI have no issues of playing EAC3 Atmos on my Shield, Emby will convert it to DD anyway. This is not an issue on my end. But on Chromebook, the same media is not converted properly by Emby either to AAC or MP3. On a browser, the audio is converted to MP3 so it plays well. I just don't understand why Emby does not convert the audio to a compatible audio for Chromebook now. This was never an issue in the past.
visproduction 335 Posted February 23 Posted February 23 (edited) Of interest: https://support.google.com/chromebook/answer/2982029?sjid=5743134076073193503-NC Quote Audio Issues on Chromebook After December 2025 Update Common Causes of Audio Errors Missing Drivers: After updates, some Chromebooks may not have the correct audio drivers installed. This can lead to the system not detecting audio devices. Firmware Requirements: Certain hardware may require non-free firmware files to function properly. If these files are not available during installation, audio issues can arise. Troubleshooting Steps Check Volume Settings: Ensure that the volume is not muted. Click on the status bar in the lower right corner and adjust the volume slider. Verify Audio Output Device: Go to Settings > Device > Audio. Make sure the correct output device is selected. Install Required Packages: For Linux-based systems, ensure that packages like sof-firmware and alsa-ucm-conf are installed and up to date. Run Audio Setup Scripts: Use scripts like setup-audio to configure audio settings. This can help detect and enable the correct audio drivers. Clear Browser Cache: If audio issues occur while using web applications, clear the browser cache and reload the page. Additional Considerations Kernel Version: Sometimes, changing the kernel version can resolve audio issues. Consider switching to a Long-Term Support (LTS) kernel if available. Check for Updates: Ensure that your Chromebook is fully updated, as subsequent patches may fix audio-related bugs introduced in the December update. Following these steps should help resolve audio issues on your Chromebook after the December 2025 update. === Possible hack fix? https://github.com/cjw1115/enable-chromium-ac3-ec3-system-decoding Edited February 23 by visproduction
tattler 31 Posted February 26 Author Posted February 26 Hi @visproductionI have no idea if my family's Chromebook was recently updated. It is an Acer Chromebook bought from 3 years or so ago. The Emby app on Chromebook is the issue here and not Chrome browser. It plays fine in Chrome browser (MP3 or AAC). It is the Emby for Android app that is having audio issues for certain audio codecs. It does not convert it to a compatible audio codec when playing media in Emby app. I will check the troubleshooting guide when I have the time. Thanks for the info.
visproduction 335 Posted February 26 Posted February 26 Tat, Your transcode log shows media with 25 graphic subtitles. I would guess that can cause problems. Try removing the subtitles from the content using mkvtools or getting a similar size demo test videos from online and see if either of these new media files play the audio correctly I am guessing that Emby might be looking at the default embedded subtitle and then try to convert it. Perhaps the other 24 graphic subtitles might need to be scanned for default status and just doing that for so many subs might cause a problem. This situation is typical with content pulled from a blu-ray. All those subtitles work fine with a blu-ray player, but are not nice with streaming playback. 1
tattler 31 Posted February 26 Author Posted February 26 @visproductionsubtitles aside, how do you explain that there is no audio when playing Come Fly With Me when there is only external srt subtitle present? This is what Emby supports.
Luke 42241 Posted February 27 Posted February 27 What’s probably happening is the device is reporting support for it even though it doesn’t. 1
tattler 31 Posted February 27 Author Posted February 27 7 hours ago, Luke said: What’s probably happening is the device is reporting support for it even though it doesn’t. Hi Luke, how do you explain that Once Upon a Time In China is correctly converted to AAC while others not? I am baffled if the device is reporting support for something that it does not? This is not consistent in my opinion. If what you said is true then no audio will be playing for all files, right?
Luke 42241 Posted March 5 Posted March 5 On 2/27/2026 at 2:37 AM, tattler said: Hi Luke, how do you explain that Once Upon a Time In China is correctly converted to AAC while others not? I am baffled if the device is reporting support for something that it does not? This is not consistent in my opinion. If what you said is true then no audio will be playing for all files, right? In one of the above ffmpeg logs it is transcoding due to quality setting, not audio compatibility. If you were to raise the quality setting then in theory you might run into the same issue with that file.
tattler 31 Posted March 6 Author Posted March 6 (edited) On 05/03/2026 at 05:25, Luke said: In one of the above ffmpeg logs it is transcoding due to quality setting, not audio compatibility. If you were to raise the quality setting then in theory you might run into the same issue with that file. Hi Luke, do you mean the remote stream quality (Mbps)? I already set it to 30 Mbps max. Doesn't Emby check for audio compatibility when starting a movie? Edited March 6 by tattler
Luke 42241 Posted March 6 Posted March 6 10 hours ago, tattler said: Doesn't Emby check for audio compatibility when starting a movie? Yes but what I'm suggesting is the device might be incorrectly reporting support for it. Quote Hi Luke, do you mean the remote stream quality (Mbps)? I already set it to 30 Mbps max. The video is higher than that.
tattler 31 Posted March 8 Author Posted March 8 I appreciate the suggestions so far, but I’ll be honest: I’m feeling a bit disappointed with the lack of progress on this. It feels like we are relying on guesswork rather than a technical deep dive into the root cause. I would honestly prefer to hear that this is a known bug or a technical limitation rather than continuing with 'trial and error' fixes that don't seem to get to the bottom of what I’m experiencing. I don't mean to be rude, but I’m looking for a more definitive technical answer.
visproduction 335 Posted March 9 Posted March 9 Tat, Consider you may have a collection of media that has not perhaps been conformed to all one standard and limited to specific codecs and bandwidth that are compatible and works for your hardware and for all your users. Yes, of course, Emby's advantage is that it can take care of that for you. But there can be limits. Maybe some of your media has timeline errors that only show up if you run a error probe check. Or some of your media might have a combination of high bit rate, high frames per second, high end audio and graphic subtitles all at once. This combination can be handled by Emby... but some server capacity and bandwidth for some remote users with different players and networks might NOT work 100%. OK, I understand you do not want have to test, remux or renecode your content, so it's all within some limit to make sure everyone can view it. But if you did do that, your issues might go away. Emby is suppose to be able to handle that. All online commercial streaming sites already do this automatic remux and limits all of their content, before any media even appears on their site. You are asking Emby to handle all the options that is not even done by any competitive service. Plex doesn't offer that. I believe Plex uses their servers. Online Netflix, Hulu, or Prime doesn't do that, their content is all remuxed and tested. I think that getting to the bottom what you're experiencing is that you are pushing the limits, beyond what can be expected to be handled automatically for every case on every media combination. If you want less errors, for the most part, you should use media that has bandwidth limits, specific audio codec and limited subtitle types so your media is more consistent. Using media that has many differnet issues, that might even have some uncaught file or timeline errors is always going to cause your streaming to run into problems. 2
