EMBY-PLEX-MEDIA-SERVER 0 Posted January 29 Posted January 29 (edited) When trying to play trailers you click on them and they just auto back out does not even try and play. Ran through all troubleshooting steps, Cleared Cache. Reset Box. Uninstalled Emby on Nvidia Shield and then re-installed. Still same issue. Edited January 29 by softworkz
seanbuff 1355 Posted January 29 Posted January 29 13 minutes ago, EMBY-PLEX-MEDIA-SERVER said: When trying to play trailers you click on them and they just auto back out does not even try and play. Ran through all troubleshooting steps, Cleared Cache. Reset Box. Uninstalled Emby on Nvidia Shield and then re-installed. Still same issue. Since this is your first post. I must ask, have you posted this in the correct forum? This forum is for the WMC UI version of the Emby client. Is that the app you are having issues with? Please provide the version number of the affected app, thanks.
