SamES 1088 Posted 2 hours ago Posted 2 hours ago Do you set the Shared Network path on folders in your library or do you leave it blank?
SamES 1088 Posted 2 hours ago Posted 2 hours ago (edited) Do you use a reverse proxy or just standard port forwarding? Edited 2 hours ago by SamES
brainfryd 10 Posted 2 hours ago Posted 2 hours ago 3 minutes ago, SamES said: Can you also try removing this limit for a test? 2 minutes ago, SamES said: Do you use a reverse proxy or just standard port forwarding? I never quite got my head around reverse proxy, kind of wanted to... So just port forwarding in router ... Can try removing the limit, may not get an answer until tomorrow
SamES 1088 Posted 2 hours ago Posted 2 hours ago Just now, brainfryd said: Can try removing the limit, may not get an answer until tomorrow Thanks Is the client side running anything like PiHole, or anything else recently that might be blocking or affecting network traffic. It's like the media requests/response from the TV is getting blocked
brainfryd 10 Posted 2 hours ago Posted 2 hours ago Also just to recap... The user can log into an LG TV or a Fire TV in the same house and have no issues with playback, so I don't think it's a user policy issue either, but happy to try it
brainfryd 10 Posted 2 hours ago Posted 2 hours ago 3 minutes ago, SamES said: Thanks Is the client side running anything like PiHole, or anything else recently that might be blocking or affecting network traffic. It's like the media requests/response from the TV is getting blocked Nope... No additional services, just a basic router with no recent changes, same internet /wifi setup has been in place over 12 mths and as mentioned other devices in the house can connect to Emby with no issues Also just confirmed, removing the remote steaming settings on the server has not helped /changed anything 1
SamES 1088 Posted 1 hour ago Posted 1 hour ago 30 minutes ago, brainfryd said: I looked at the playback attempts from earlier today and the file that the log is referring to IS a basic 1080p mkv with Ac-3, so it should just direct play... I've attached a screenshot for the media info from Emby. Correct, but I could see a bitrate limit of about 7mb/s on that playback attempt, so it would have still been trying to transcode. Do you want to set me up with a remote account and access to a few of these files, then PM me the connection details? It will be interesting to see if I can playback. That might help us to know if it's on the server or client side. 1
brainfryd 10 Posted 1 hour ago Posted 1 hour ago 14 minutes ago, SamES said: Correct, but I could see a bitrate limit of about 7mb/s on that playback attempt, so it would have still been trying to transcode. Do you want to set me up with a remote account and access to a few of these files, then PM me the connection details? It will be interesting to see if I can playback. That might help us to know if it's on the server or client side. OK... can do, i'm assuming you have a Samsung TV then ... but can i also just mention that even music playback is failing ? Will PM you details shortly
