soderlund 113 Posted January 28 Posted January 28 Hi! With the new BETA 4.10.0.1 release we can now customize the home screen (freaking awesome!). I made a simple script with help of ChatGPT that looks at a Trakt list and compare it to your library. If the movie/show is in your library it will give that item a tag of your choosing. When the movie is no longer in the Trakt list the tag will be removed from that movie. This will be really useful for the new home screen customization to create a dynamic homescreen. I'm no coder so if anyone want to develop this furher please do! And maybe help me develop it into an actual plugin? https://github.com/soderlund91/emby-tag/tree/main 2
soderlund 113 Posted January 29 Author Posted January 29 (edited) Just made an update of the code. Now supporting MDBList aswell. Edited January 29 by soderlund91
soderlund 113 Posted January 30 Author Posted January 30 2 hours ago, Raichi said: Hi soderlund9, Is this a plugin? How do you set it up? Hi, No this is just a code that you run from your terminal/command prompt at the moment. My ambition is to make it into a fully functional plugin, but that is beyond my knowledge and lack of time is also a factor.. Anyway.. Download the file “auto_tag.py” and place it wherever you want on your computer. Edit the file in a text editor according to the setup instructions. I have left a few examples in the code for both Trakt and MDBlist. Then run the code by typing “python3 /path/to/the/file/auto_tag.py” 1
