Trelane 38 Posted January 28 Posted January 28 Emby for Android 3.5.28 has broken AV1 direct play on both my FireTV Cube 3rd Gen and my FireTV Television. AV1 directplay playback worked fine prior to this latest version being released. Now all Av1 playback claims the video codec is not supported. Emby for Android 3.5.28 + Emby Server 4.10.0.1 Anyone else confirm they are seeing the same? Thank you. 2
Trelane 38 Posted January 28 Author Posted January 28 (edited) Both devices have Av1 hardware decoding and worked perfect prior to 3.5.28 upgrade. Now it detects it as not supported on both devices. I am a heavy AV1 user, so all my devices were bought with AV1 in mind. GoogleTV (onn 4k) devices work fine on the same 3.5.28 code. Device Specifications: Fire TV Cube | Amazon Fire Device Specifications Edited January 28 by Trelane
Trelane 38 Posted January 30 Author Posted January 30 Fire Television -> Fire OS 7.7.0.8 (PS7708/5501) FireTV Cube (3rd gen) -> Fire OS 7.7.1.1 (PS7711/5272) Which I believe are based on Android 9.
slevin7 86 Posted February 2 Posted February 2 I can confirm the same behavior on my FireTV. AV1 direct play stopped working recently. If I remember correctly, it was still working around version 3.5.21 or 3.5.23 - unfortunately I can't say for certain which exact version. 1 1 1
Solution Trelane 38 Posted February 11 Author Solution Posted February 11 This appears to be fixed in the latest release, v3.5.29. that just hit github. Tried a few AV1 encodes files on my Fire Television. Good to go. Thank you for the very quick turn around on this. Most appreciated. https://github.com/MediaBrowser/Emby.Releases/raw/master/android/emby-android-google-armeabi-v7a-release.apk 1
unrais 15 Posted March 3 Posted March 3 (edited) On my Nvidia Shield Pro (no AV1 HW Decoder) with Emby for Android 3.5.16 and Emby Server 4.9.3.0 I was able to play AV1 fine without transcoding (sw decoder), but just switched to Emby for Android 3.5.30 & Emby Server 4.10.0.4 (For the newer homescreen features) and AV1 no longer plays without transcoding. Is it a regression @Luke? Update: As a test I tried the Android 3.5.16 version of the Emby app again and it played fine (still on the latest beta version of the server). I then tried the latest version that's on PlayStore (3.5.28) and that one doesn't play. So something seems to have happened between 3.5.16 and 3.5.28 at least that's stopped it working. Edited March 3 by unrais
unrais 15 Posted March 5 Posted March 5 5 hours ago, Luke said: HI, we'll take a look at it. Thanks. 3.5.30 also breaks SW AV1 playback on Nvidia Shield Pro (works in 3.5.16 and apparently was broken in 3.5.28 but fixed again in 3.5.29). If that could be looked at please?
Luke 42241 Posted March 6 Posted March 6 @unrais Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
