Pilot1966 0 Posted January 28 Posted January 28 I have the ONN 4k plus streaming box with the included remote minus the "pause" button. Having read the suggestions offered on the search panels none works as stated. Pressing the middle button only transitions from the timeline to the the program menu, any other suggestions?? Thank in advance
Luke 42241 Posted January 28 Posted January 28 hi, what search panels do you mean? Search inside Emby?
Pilot1966 0 Posted January 28 Author Posted January 28 I have searched on Google and also I have followed the suggestions on YouTube
ebr 16334 Posted January 28 Posted January 28 12 hours ago, Pilot1966 said: Pressing the middle button only transitions from the timeline to the the program menu, Hi. Once the OSD is up, isn't there a "Pause" button right there on the screen?
Pilot1966 0 Posted January 28 Author Posted January 28 I have searched on Google and also I have followed the suggestions on YouTube. Both provide the same suggestions with no resolve.
Pilot1966 0 Posted January 28 Author Posted January 28 No. I have gone through all of the OSD and none provide me with the PAUSE options.
Pilot1966 0 Posted January 29 Author Posted January 29 No I am not. Should I and if so are referring the device as my onn
ebr 16334 Posted January 30 Posted January 30 Hi. This is the support forum for Emby - a personal media server system. If you are not using that, I'm afraid we will have limited ability to help you.
Neminem 1623 Posted January 31 Posted January 31 Well do you have the server installed? Without that getting the app is pointless Quick Start
ebr 16334 Posted January 31 Posted January 31 Hi. It is also pointless unless you have your own content.
