Przemek 70 Posted January 27 Posted January 27 Hi, I recently very often I have situation that current Emby app for Android TV stutters/freezes every 2 seconds during playback. It's so bad that it's completely unwatchable on: Amazon Fire TV Cube Canal+ BOX (Android TV) Firecube and C+box are on the completly different houses and cities. On the Fire TV Cube I had to go back to the old "Emby for Fire TV" app – that one works perfectly, no stuttering at all. I attach logs. There was 21:49 when I must shutdown Android app because I cannot watch and I run Emby for Fire tv. Anyone else seeing this? embyserver.txt ffmpeg-transcode-d2a0ecc2-86a9-428f-887b-a82a7f73b4bb_1.txt
Solution Luke 42243 Posted January 28 Solution Posted January 28 Hi, can you try setting the quality back to auto and see if that helps? That may help you avoid the transcode on the LAN. Thanks.
Przemek 70 Posted January 29 Author Posted January 29 Hi @LukeThanks, it looksl like that helps. Regards. 1
