ivanrakic 2 Posted January 19 Posted January 19 Hello, I recently purchased Emby Premiere and noticed a change in the behavior of the LG Magic Remote channel up/down buttons. Previously, after selecting “Play from here” in a folder view, the channel up/down buttons would move to the next or previous video in the folder. Now, those same buttons appear to navigate chapters within the currently playing video instead. I am trying to understand whether: This behavior changed after activating the Premiere subscription, or It was introduced by a recent update, or This behavior may never have existed on LG TVs and only worked this way on Android clients. Additionally, would it be possible to introduce a settings option that allows users to choose what the channel up/down buttons control (e.g., chapter navigation vs. next/previous item)? Thank you for your time and clarification.
SamES 1082 Posted January 20 Posted January 20 It's due to a recent change for the channel up/down keys. It should always have been changing channels during video playback, but was incorrectly changing prev/next. https://emby.media/community/index.php?/topic/142706-lg-remote-numbers/#findComment-1472058 Do you have these buttons visible on the OSD, they will skip to prev/next episodes
ivanrakic 2 Posted 4 hours ago Author Posted 4 hours ago Sorry for the late reply. The OSD previous/next buttons are very inconsistent for me. Sometimes they appear, sometimes they don’t. I have a lot of music videos, and I used to quickly go through them using the Channel Up/Down buttons on the remote. Now those buttons cycle through (auto-generated) chapters instead, which is not useful in my case. Is it possible to customize the behavior of remote buttons so the user can choose what they do? Alternatively, is there a way to remap these functions manually, or use other available buttons on the remote for this purpose? Thanks.
SamES 1082 Posted 3 hours ago Posted 3 hours ago The visibility of some of the OSD buttons depends on detection of a mouse or the LG magic pointer. Check the app settings, there is a setting possibly under Display or Playback where you can set the transport button visibility. Try setting it to ‘always show’
SamES 1082 Posted 3 hours ago Posted 3 hours ago And Prev/Next buttons will only ever appear if there are Prev or Next items, so Prev won’t show for the first item in a queue, and neither will show if playing a single item.
