Rusck 0 Posted January 16 Posted January 16 Basically that, whenever I play a file with Flac audio, it keeps going mute for about a split second every ten seconds, creating a very annoying effect
Luke 42233 Posted January 16 Posted January 16 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Rusck 0 Posted January 16 Author Posted January 16 (edited) Started reproducing the file at 2026-01-16 14:40:20.491 on what the device calls Direct Play (the one in which the problem occurs) Took about one minute for the problem to begin, then it started to happen repeatedly embyserver (1).txt Edited January 16 by Rusck extra information
Luke 42233 Posted January 16 Posted January 16 OK looks like it was direct playing without any server transcoding, so that means the LG video player is just having trouble with this particular file. You could use the playback correction button in the video player to switch to transcoding and this may resolve it.
