Luke 42233 Posted January 27 Posted January 27 7 hours ago, trekflix said: Hi @Luke I'd like to know if it will still take a while for them to fix this problem with Emby for LG TVs. It's been more than 2 weeks since I noticed the problem. Sorry for insisting, but it's becoming too disruptive. Hi, the plan is for this week. Thanks. 1 1
trekflix 5 Posted February 2 Author Posted February 2 On 1/26/2026 at 11:10 PM, Luke said: Hi, the plan is for this week. Thanks. My friend @Luke, Any updates on the issue? While we're at it, would you know if we'll ever get the Emby app for Samsung TVs in Brazil?
Luke 42233 Posted February 3 Posted February 3 8 hours ago, trekflix said: My friend @Luke, Any updates on the issue? While we're at it, would you know if we'll ever get the Emby app for Samsung TVs in Brazil? Hi, it is still the same. Regarding Samsung, please see this topic:
trekflix 5 Posted February 11 Author Posted February 11 @LukeMe again. I didn't imagine this update error could be so complicated to fix. Is there an update available? It's really difficult having to extract the embedded subtitles from my TV shows to save them as an external file.
visproduction 335 Posted February 11 Posted February 11 MKVCleaver V 0.8.0.1 64 bit for Windows extracts subs pretty easily. You can load many .mkv videos at once select whatever subs you want and click Enter. You could do hundreds at a time. I suggest this older version. The latest update has some issue with false positive virus check. You can also extract a new version of video + audio, without the subs. Both these processes take under a minute for each 2 hour media.
Tafaner 0 Posted February 15 Posted February 15 Hello. I'm not sure if it would be wise to revert to the previous version of the Emby app on LG TVs until a solution is found. Besides giving the impression that it's not applying or correctly reading special character encoding, if you fast-forward or rewind the video on the LG TV (with the app acting as an Emby client), the subtitle timing gets messed up. This doesn't happen when watching the MKV video on a PC with Emby as the server. Regards ____________________________________________________ Hola. No sé si sería prudente en los televisores LG revertir a la versión anterior de la app de Emby mientras no encuentren la solución, ya que, además de dar la sensación que no se aplica o no lee correctamente la codificación de caracteres especiales, si se adelanta o retrocede el video en el televisor LG (actuando la app como cliente Emby), se desajusta el tiempo de los subtítulos, mientras que eso no ocurre si visionamos el video en mkv en el pc con Emby como servidor. Saludos
visproduction 335 Posted February 15 Posted February 15 Trek, The sample .srt you attached did not have the 2 letter country codes in the file name. For Portuguese, they should be named either: Fallout.S02E05 - O Vaqueiro.br.srt Fallout.S02E05 - O Vaqueiro.pt.srt WIthout the two letter code you could run into the font problem. Just a guess. Ebedded files in the media, might also have some tagged language issue. Just because the subtitles should be portuguese, doesn't mean the tag id in the media is correct. Original content can also be limited for broadcast and playback on disc to different world zones. Is this media broadcast to Portuguese speaking country, Brazil or Portugal? Or is this media copy coming from another world zone? If you have a copy of a media with a world zone on broadcast or on a blu-ray disc set for North America, it may not work correctly for subtitles in South America or Southern Europe
trekflix 5 Posted February 15 Author Posted February 15 19 minutes ago, visproduction said: Trek, The sample .srt you attached did not have the 2 letter country codes in the file name. For Portuguese, they should be named either: Fallout.S02E05 - O Vaqueiro.br.srt Fallout.S02E05 - O Vaqueiro.pt.srt WIthout the two letter code you could run into the font problem. Just a guess. Ebedded files in the media, might also have some tagged language issue. Just because the subtitles should be portuguese, doesn't mean the tag id in the media is correct. Original content can also be limited for broadcast and playback on disc to different world zones. Is this media broadcast to Portuguese speaking country, Brazil or Portugal? Or is this media copy coming from another world zone? If you have a copy of a media with a world zone on broadcast or on a blu-ray disc set for North America, it may not work correctly for subtitles in South America or Southern Europe Friend, regarding using Pt-br in the external subtitle file, I don't know if it influences the Emby system defect. The problem occurs when the subtitle is embedded, even in cases where Portuguese (Brazil) is specified. Every video with an external SRT subtitle file reads the subtitle correctly. I tried using the program you mentioned, but it extracts the subtitle and inserts _track4 in the file name, and Emby doesn't recognize it. I would have to rename each extracted subtitle, and that's impractical. The problem isn't with the files themselves; it's an update error. I've been using Emby for years, and only now has this subtitle error occurred, which is causing significant problems. I'll wait for the technicians to fix this or at least revert the LG TV's Emby to the previous version, without this error. Imagine having to rename each subtitle for a series like Grey's Anatomy, which has 22 seasons. I'll wait for the system to be fixed or for them to revert to the previous version without this defect. 1
BroserBros 0 Posted February 16 Posted February 16 Same problem in LG WebOS TV. Usually I'm using tr-TR subtitles. Also, the problem has been present for 2-3 weeks, and I wanted to ask if downgrading the Emby server to a previous version would solve the problem?
SamES 1084 Posted February 17 Posted February 17 On 15/01/2026 at 00:16, trekflix said: These are examples of videos where the subtitles have a problem right from the start. The subtitle file (.srt) is also attached. Greys.Anatomy.S22E07 - Skyfall (1)-001.mkv 9.82 MB · 1 download Greys.Anatomy.S22E07 - Skyfall (1)-001.srt 445 B · 1 download I'm not seeing this problem now with your files Can you please confirm your current server and app version?
trekflix 5 Posted February 17 Author Posted February 17 48 minutes ago, SamES said: I'm not seeing this problem now with your files Can you please confirm your current server and app version? APP in LGTv: 1.0.50 Server Version: 4.9.3.0
SamES 1084 Posted February 17 Posted February 17 7 hours ago, trekflix said: APP in LGTv: 1.0.50 Server Version: 4.9.3.0 Perfect. I'm on the current server beta, so hopefully this is fixed for you in the next server releases.
Tafaner 0 Posted February 18 Posted February 18 16 hours ago, SamES said: Perfect. I'm on the current server beta, so hopefully this is fixed for you in the next server releases. I appreciate you trying to resolve the issue, but I believe the problem lies with the LG TV app 1.0.50, as it doesn't correctly interpret symbols or accents in subtitles, whereas it did in previous versions, not with the server. _________________________________ Agradecido de que estés tratando de solucionar la incidencia, pero creo entender que el problema está en la APP 1.0.50 para Tv LG, al no interpretar correctamente los símbolos o acentos en los subtítulos cuando sí lo hacía en versiones anteriores, no en el servidor.
coolspot 22 Posted February 19 Posted February 19 It probably is server version related as it may be related to which is temp fixed by us rolling back server version. It just happened to begin after an LG client update as well so took a bit to link it to the server build.
BroserBros 0 Posted February 28 Posted February 28 On 2/19/2026 at 10:57 PM, coolspot said: It probably is server version related as it may be related to which is temp fixed by us rolling back server version. It just happened to begin after an LG client update as well so took a bit to link it to the server build. What server version did you back to?
trekflix 5 Posted March 3 Author Posted March 3 On 2/17/2026 at 5:06 PM, SamES said: Perfect. I'm on the current server beta, so hopefully this is fixed for you in the next server releases. Hi @SamES Do you have an estimate of when we will have an update on the Emby server and app for LG TV?
SamES 1084 Posted March 4 Posted March 4 15 hours ago, trekflix said: Hi @SamES Do you have an estimate of when we will have an update on the Emby server and app for LG TV? Sorry, I don't. It is only the server update that you should need to resolve this
zodac01 3 Posted March 22 Posted March 22 Hi, I'm seeing my subtitles just cutting out maybe 5 minutes before the end of the stream. Works fine on my non-LG devices. Not sure if it's the same root cause as the issues listed in this thread, since the subs do work for most of the episode. But they are embedded subs having issues. Or should I make a fresh thread with logs?
fabien_m2002 8 Posted March 22 Posted March 22 5 hours ago, zodac01 said: Hi, I'm seeing my subtitles just cutting out maybe 5 minutes before the end of the stream. Works fine on my non-LG devices. Not sure if it's the same root cause as the issues listed in this thread, since the subs do work for most of the episode. But they are embedded subs having issues. Or should I make a fresh thread with logs? Hello same issue i guess. I hope it will solve soon. Apparently lastest beta did not, so i am afraid there is no solution yet 1
