user84 49 Posted January 10 Posted January 10 Currently I have all of my documentaries either in my TV shows library, or my Movies library. Then I've created a Collection called "Documentaries" that has them all listed. I recently considered creating a separate library called "Documentaries" that would allow me to have them in their own library, but I'm realizing that some of them are TV show episode based, and some are movie based. I've been reading up on how others set things up, and people seem to have a negative experience using the "mixed content" option Anyone have any advice about how to set any of this up properly in 2026? Is my setup the best option?
Neminem 1630 Posted January 10 Posted January 10 Well if they are movies pr. metadata providers depending on provider set them up as that folder structure wise. If metadata suggest they are tv series, the set them up as tv shows folder structure wise. Never done this my self but remembering my battle with metadata about Red Rose (2002). And in the day I thought it was a long movie Rose Red (TV Series 2002-2002) — The Movie Database (TMDB) Rose Red - TheTVDB.com
RanmaCanada 503 Posted January 10 Posted January 10 As long as you have the proper metadata providers enabled, and the files properly named, you can have them all in there. I have a documentaries section that is both movies and TV shows and it's only the documentaries that are part of a tv series, that are an issue. So for example, if documentary is presented as a movie, but it is instead an episode of a long running tv series, just that it is "identified" as a movie or special, it can become a problem. It always comes down to the metadata that is available, and the wankers at TVDB always find a way to screw things up. Just be on top of your naming scheme and your fight should be minimal.
porkbone 48 Posted January 10 Posted January 10 I have them mixed in the same folder too. When creating the new library, select Mixed Content. Just make sure your Movies and TV shows have been identified.
pwhodges 2039 Posted January 12 Posted January 12 When using Mixed Content library type, it is especially important to follow Emby's Movie and TV naming guidelines closely, as the folder structure is the main thing which enables Emby to decide which items are of each type. Paul 1
