Hispanico957 23 Posted January 30 Author Posted January 30 I hope so because unfortunately I have a lot of TV series to sort out due to this bug... Thank Hispa
Hispanico957 23 Posted February 12 Author Posted February 12 (edited) Hi mate i refer your file scifi.py I comeback to adjust this problem..but when i launch your file (modified) this run, show the tvseires founf but at the end it close..not showing results.. Where i wrong ?? pheraps i dont remeber well the procedure.. Thank Hsipa Edited February 12 by Hispanico957
Hispanico957 23 Posted February 15 Author Posted February 15 On 1/23/2026 at 4:41 AM, Luke said: Hi, we are still looking at this. Thanks. When solve/fix this bug ? PLS Thank Hispa
Hispanico957 23 Posted February 16 Author Posted February 16 (edited) So I think it's a real bug... the problem persists even if the .nfo file is correct, see attachment, and the series appears in the empty ones. I also tried deleting the nfo file, but absurd! It still appears. Only by removing the series from the NAS... it no longer appears. I also tried putting back just the video files, but the same problem. Even checking with the cochize1 file doesn't find anything, but it appears in the series genres. Also @Recycle not exist See screnshot...a genre AZIONE appear, but is blanck, if i click play...the episode of Chernobyl play ... and in file nfo not exist genre "Azione" PLS FIX this nightmare Thank Hispa Chernobyl - S01E01 - 1.23.45.nfo Chernobyl - S01E01 - 1.23.45.nfo Edited February 17 by Hispanico957
Hispanico957 23 Posted February 18 Author Posted February 18 (edited) And again why this BUG happened only in TV-SERIES and not for example in movie ?? Thank for FIX at soon at possible Hispa Edited February 18 by Hispanico957
Hispanico957 23 Posted March 5 Author Posted March 5 On 2/19/2026 at 7:12 AM, Luke said: Hi, we are looking into this. Thanks. Still no solution or fix?? Hispa
