pfm55 0 Posted January 8 Posted January 8 I have a phantom drive that appears as a folder in my Emby libraries. How can I remove it? There is no option to delete the folder in either the Emby Server or the Emby app. Additionally, I am trying to use a third-party player. When I enabled this feature in Emby, I mistakenly selected the wrong player for "always use" instead of just "use once." How can I reset this setting so both options reappear and I can select the correct one?
Luke 42287 Posted January 9 Posted January 9 Hi there, can you please show a screenshot example of what you are referring to? Thanks.
Luke 42287 Posted January 9 Posted January 9 Quote I mistakenly selected the wrong player for "always use" instead of just "use once." How can I reset this setting so both options reappear and I can select the correct one? This is actually an android menu, not an Emby menu. I think you'd have to do that in android system settings.
