Subtitles in Upper Left Corner
4 hours ago, visproduction said:
Well OK, consider though that if LG did an update you didn't notice or some other update happened, not Emby, the symptom could be the same.  Subs used to work and now they don't.  To really test that it is an Emby issue, can someone see if the subtitles from these files still work on an older Emby version?  Until you test that it could be some other change that caused this problem.
It works perfectly on Emby 4.9.1.80; the problem isn't with our LG TVs, but with Emby itself—it's the server version or the LG app. Luke said a month ago that they were preparing a new server version that would fix this, so they're already implying that it's not a problem with LG TVs but with the Emby server.
And no, we're not going to use third-party software to extract subtitles or change the format. That's why we're using Emby, so it can automatically manage all of that. I don't know about the others, but some of us have more than 5,000 files (mostly in original version with subtitles), and we're not going to do that one by one.
This problem has been going on for two months now, and if a solution isn't offered, LG users will have to consider migrating to another platform, because this is a significant issue, and LG users keep experiencing playback problems.
  • Like 4
visproduction
NA,
Thanks.  Seems like you have pinpointed it correctly.  It would be nice to know the cause and fix, when it's resolved.
'One by one' can be streamlined to potentionally one click to extract, convert and replace all 5000 media files and possibly a few sessions to transcode graphic subs to .srt. Repeating commands one at a time, is not required, once you set up a batch.  I am not sure from your post, if you were already aware that was possible.
  1. ffmpeg or mkvtools can be scripted to extract all the subtitles, from every media file, all at once and replace the original media with copies that have no embedded subs. (Back all files up first.) -  [ One click or Enter key for each directory tree. ]
  2. There is also a batch conversion option to change graphic subs to srt.  Those could also all be done at once. Example software: https://subtitletools.com/convert-sub-idx-to-srt-online - [ Drag and drop all files to convert. ]
An extra plus, after auto extracting and converting, is that the demand on your server will be improved.
Edited by visproduction
  • Facepalm 1
  • Disagree 1
  • Agree 1
Ultroman
9 hours ago, visproduction said:
NA,
I cannot fathom how someone can suggest, that the preferred fix is to (manually or with scripting) demux, alter and remux every single video file that we have and will ever acquire in the future. That is not happening, and I will be moving to Jellyfin or Plex within the week if this isn't fixed by then. I can't watch anything, unless I set it to transcode, which breaks HDR for most files, and besides my server hardware is simply not beefy enough to transcode 4K HDR with subtitle burn-in on top.
With so much of the good content coming out having non-English speaking roles or such a terrible audio mix that you can't hear what is said half the time, subtitles are critical for the viewing experience. Waiting months for functioning subtitles is crazy for a media server service, regardless of whether it's LG or Emby that is at fault.
FYI: I haven't updated my TV since I installed the last version, so it has to be Emby that has messed something up. I always update the TV and Emby app at the same time precisely for this reason.
Edited by Ultroman
  • Like 1
  • Agree 1
seanbuff
@Lukecare to chime in here?
Are there any plans to have this issue resolved in an upcoming update?
Edited by seanbuff
  • Agree 1
visproduction
Ultro,
Sure, your choice. I understand you would like Emby to work best with your setup and getting that done is a valid request.
Does anyone get graphic subs to playback directly?  I don't use those.  If the graphic subs force an Emby transcoding, then it's your server that has to do it.  Your comment says it's not beefy enough for 4K.  So, hopefully, direct playback is possible.  I was under the impression that graphic subs usually force a transcode.
It takes about 30 seconds to 2 minutes to get the subs and make a new version media, without subs, for each 4K 2 hour video.  It's not a transcoding level event.  Of interest, is that all commerical streaming sites have already done this for all their content.  They all do that automatically using some custom script.
  • Facepalm 2
  • Agree 1
HarryShepard
The app should have a subtitle offset option to temporarily fix issues like this in the future while a real fix is found. It has been 2 months of being unable to watch anything with subs
  • Like 1
  • Agree 1
NAA67
On 2/28/2026 at 7:47 PM, Luke said:
Hola, disculpas por el retraso. Pronto publicaremos una actualización del servidor para resolver esto. Gracias.
And what about the subtitle positioning error? What's the status of that?  @NAA67
HI, apologies for the delay. We should have a server update out soon to resolve this. Thanks.
  • Like 1
  • Thanks 2
Wayne1801
Could you please inform me about any updates, I only have the issue on my LG TV.
Regartds
Wayne
SYN01
This problem has only starting happening recently for me as well. I am running Emby 4.10.0.5-beta x86 version on a Synology NAS with DSM v7.3.2 and LG TV version 1.0.50
Hoping the dev team can fix it soon as I am a huge fan of Emby and would not consider anything else!
Thanks
  • Agree 1
NAA67
Does version BETA 4.10.0.6 fix this problem? Its Release Notes mention "Fix subtitle encoding regression with LG TVs," but I'm not so sure this solves the problem since it was present in previous versions as well.
coolspot
I think the fix for this would be a new note as that release note has been in the log since the early builds of 4.10.0.2 roughly I think.
I'll hold off on updating until we get word.
SYN01
Thanks
Update: Moved to 4.10.0.6 problem still exists.
  • Like 1
  • Agree 2
I had no choice but to make a backup, uninstall Emby, and reinstall it, but with version 4.8.11.0, the subtitles and playback on LG work perfectly. It's a shame; I've had this error for three months now, and they keep saying it will be fixed in the next server update, but it never comes!
