NAA67 22 Posted January 31 Posted January 31 Hola, tengo el mismo problema en mis dos TV LG, ambas están actualizadas? Hay alguna actualización nueva en curso? Como se puede volver atrás en una actualización de LG?
Iamweazel 0 Posted February 2 Posted February 2 Reverted to earlier version 4.9.10 and working ok. Did try latest beta but not fixed yet.
coolspot 22 Posted February 3 Author Posted February 3 (edited) @IamweazelWill you verify it's 4.9.10 that you're saying works? I'm not seeing that version on Releases · MediaBrowser/Emby.Releases to roll back to. EDIT: Disregard: I wasn't going back far enough, found 4.9.1.0-beta from back in May. I'm assuming that's what you meant? I'll try it when I get a chance. Let me know if anyone finds a newer version with it working. I went and tried a few December builds and still had the subtitles in upper left corner issue (maybe because of the LG app update afterall combined with server update?) Edited February 3 by coolspot
coolspot 22 Posted February 4 Author Posted February 4 Verified rollback to 4.9.1.0-beta fixed my subtitle issue, let me know if there's a newer version that's an option. 1
Cactus 18 Posted February 4 Posted February 4 (edited) Still not working with 4.10.0.2. Any more work being done on this? Edited February 4 by Cactus 1
coolspot 22 Posted February 5 Author Posted February 5 Think they're still working on this..related to an odd character in subtitle issue mentioned on other posts as well I believe. I rolled back to 4.9.1.0 until it's fixed.
seanbuff 1354 Posted February 5 Posted February 5 24 minutes ago, coolspot said: I rolled back to 4.9.1.0 until it's fixed. 4.9.1.0 is such an old beta though, why do you need to go back that far? Did you try rolling back to 4.9.2.8 at least?
coolspot 22 Posted February 6 Author Posted February 6 (edited) Ya it's odd. I think the problem just started in early January and I rolled back to a December build but still had the problem. There may be a newer version than 4.9.1.0 that it works on but I saw that build suggested and went with it after trying a few december betas without it working right. I bet they'll have it fixed in a week or two and then I'll upgrade. Might be some combination of the .49 LG update change as well as server changes that made me have to go further back to the 4.9.1.0 but just a wild guess. If anyone finds a newer version than 4.9.1.0 that works let me know. Edited February 6 by coolspot 1
NAA67 22 Posted February 6 Posted February 6 16 hours ago, coolspot said: Ya it's odd. I think the problem just started in early January and I rolled back to a December build but still had the problem. There may be a newer version than 4.9.1.0 that it works on but I saw that build suggested and went with it after trying a few december betas without it working right. I bet they'll have it fixed in a week or two and then I'll upgrade. Might be some combination of the .49 LG update change as well as server changes that made me have to go further back to the 4.9.1.0 but just a wild guess. If anyone finds a newer version than 4.9.1.0 that works let me know. I have done the same. I updated to beta 4.10.0.1 but the error was not corrected, and thanks to you it occurred to me to go down very low and install 4.9.1.0 and it works! Thank you! Hopefully it will be fixed in the next stable version of 4.10.
Cactus 18 Posted February 9 Posted February 9 4.9.1.90 (non beta) works. https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.9.1.90 1
coolspot 22 Posted February 9 Author Posted February 9 Thanks, that's newer than what I've been running
seanbuff 1354 Posted February 10 Posted February 10 1 hour ago, coolspot said: Thanks, that's newer than what I've been running Please be aware that it is not advisable to switch back and forth between Stable and Beta builds. You could experience undesirable results.
Cactus 18 Posted February 10 Posted February 10 16 hours ago, seanbuff said: Please be aware that it is not advisable to switch back and forth between Stable and Beta builds. You could experience undesirable results. In this instance, we experience desirable results. 1
NAA67 22 Posted February 15 Posted February 15 Does anyone know if the Beta version: v4.10.0.3 (2026/02/12) fixes this?
Ultroman 89 Posted February 17 Posted February 17 (edited) On 2/15/2026 at 2:59 PM, NAA67 said: Does anyone know if the Beta version: v4.10.0.3 (2026/02/12) fixes this? There's no mention of it in the change log. I'm also experiencing this. Kind of ruined a movie night with someone I only see every 3 months Didn't want to start messing around with downgrading the server while they were there. I hope it's fixed soon. Edited February 17 by Ultroman
NAA67 22 Posted February 17 Posted February 17 I confirm that version 4.10.0.3 BETA does NOT fix the subtitle problem, although version 4.10.0.2 BETA specifies that it fixes problems with subtitles, it seems that they are not these. It's already desperate, we've been like this for 6 weeks. @Lucas 1
elbores 3 Posted February 21 Posted February 21 Still with the problem... Really annoying issue and no solution for a month... 1 1
HarryShepard 4 Posted February 22 Posted February 22 I'm still having the same issue after the LG .50 update. It no longer has the strange characters in the subs but they're still positioned in the top left corner and it's putting most of it off screen 1 1
NAA67 22 Posted February 22 Posted February 22 At least an official statement regarding the bug and its fix is needed. They said it would be fixed a month ago, and nothing has been done since. LG users are constantly experiencing problems; sometimes we feel abandoned. 1 1
NAA67 22 Posted February 25 Posted February 25 I updated to version 4.10.0.4 Beta, and although it specifies that it fixes it, it DOES NOT fix it. 1
Cactus 18 Posted February 25 Posted February 25 2 hours ago, NAA67 said: I updated to version 4.10.0.4 Beta, and although it specifies that it fixes it, it DOES NOT fix it. It doesn't say that at all. The "subtitle encoding regression" was in an earlier beta, and has nothing to do with the subtitle positioning. I don't think they're even working on this. Quote 4.10.0.4 Fix queries for some home screen sections returning wrong items Add new spotlight home screen section option Add new spotlight home screen section option (requires Emby Server 4.10+) Cumulative Changes Since Stable Release Add new home screen section type called dynamic media with sorting and filtering functions Update to sqlite 3.51.2 Fix regression with hiding users from login screens on remote connections Add sorting options to new home screen editor Add Copy Data to Users context menu command Fixes with home screen sections migration Revamp home screen section options with new section editor Add banner text option to server settings Support person credits at the bottom of person detail screens Playback fixes for Chromecast Fix subtitle encoding regression with LG TV's Fix Hardware Transcoding for HDR Video when Tone Mapping is enabled 1
visproduction 335 Posted February 25 Posted February 25 (edited) Suspect origin of issue is subtitle positioning metadata, embedded in the media file. Some TV's Apps might handle "Alignment 2" as the short term name for bottom center and other TV apps, perhaps your LG, does not have code to recognize "Alignment 2" and considers it, instead, to be center aligned, from top left. This is just a guess. This type of strange issue can come from an online software update from LG. The media file subtitle positions can be fixed with ffmpeg. If this is true, then Emby would, at the most, be trying to fix an issue, caused by the media file. Maybe a previous Emby version had some process working to fix this. The better solution is to fix the media file embedded subtitle positions. Have examples been found where the exact same media file works on a different Emby version? Fixing embedded subtitle positions by resetting the metadata inside the media file. see: https://stackoverflow.com/questions/57869367/ffmpeg-subtitles-alignment-and-position === A fix I prefer is to remove the subtitles from the media file and convert them to separate .srt files. Remove - MkCleaver (older verison 0.8.01 because the new version has false virus issues) Convert - https://subtitletools.com/convert-sup-to-srt-online Edited February 25 by visproduction
coolspot 22 Posted February 26 Author Posted February 26 Yes, it's been confirmed that exact same media files work on older Emby server versions.
visproduction 335 Posted February 26 Posted February 26 (edited) 21 minutes ago, coolspot said: Yes, it's been confirmed that exact same media files work on older Emby server versions. Well OK, consider though that if LG did an update you didn't notice or some other update happened, not Emby, the symptom could be the same. Subs used to work and now they don't. To really test that it is an Emby issue, can someone see if the subtitles from these files still work on an older Emby version? Until you test that it could be some other change that caused this problem. Edited February 26 by visproduction
