Ashbless1975 0 Posted January 7 Posted January 7 Hello, I am experiencing an issue with my Emby sessions. Until recently, I was able to have up to 4 devices logged in simultaneously (2 TVs, an iPhone, and an iPad). Although I only played content on one device at a time, I could browse the menus on all of them without being logged out. The problem started after I tried to connect a new Amazon Fire TV Stick 4K Max. Since then, the system automatically logs me out of all other devices whenever I try to have more than one session active. Even after removing the new Fire Stick and logging out of it, I can no longer maintain two devices connected at the same time; as soon as I log into one, the other is kicked out. My server provider suggests this is a software-side issue with Emby's session management. • I do not have Emby Premiere. • I do not have access to the 'Devices' tab in my settings (it seems hidden by the admin). • I have tried clearing the cache and reinstalling the apps on my mobile devices, but the 'one-session-only' behavior persists. Is there any specific reason why adding a new device would trigger this logout loop or change the session behavior for my user? Is there any way to force a global logout to reset my active sessions? Thank you for your help.
Neminem 1623 Posted January 7 Posted January 7 (edited) 2 hours ago, Ashbless1975 said: I do not have access to the 'Devices' tab in my settings (it seems hidden by the admin). This must mean that you are just a user, on someone else's server, right? So you would need to talk to that guy. If this is your server installed on your own hardware. Then dev's would need logs. Edited January 7 by Neminem Adding info
ebr 16335 Posted January 7 Posted January 7 Hi. It sounds like your server admin is using a plugin that limits your access. You will need to talk to them. Thanks.
